Question about RCA R52WM24 52" HDTV Projection Television
Replace a fuse R52WM24
Can i replace fuse fl231 which is a T400MA 125V with a pico micro fuse 500 MA 125V
  • RCA Master
  • 8,617 Answers
You can temporarially. Its recomended not to exceed fuse ratings especially the amperage do to pretective reasons. You can get the proper FL231 fuse at the following link. They have a 10.00 minimum order for free shipping so you may have to order enough fuses to add up to 10.00 or pay for shipping if under 10.00 Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 18, 2009
How do you test a fuse
How do you test a fuse?
• for RCA FL231
(400ma, 125V) +40V Supply Power Supply/Deflection PCB
OEM RCA FUSE RCA259213 FL231 400MA 125V 3960400000 ...
• for
FL221 (1.25, 125V) -13V Supply Power Supply/Deflection PCB
FL251 (1.25A, 125V) +13V Supply Power Supply/Deflection PCB
FP400 (6A, 125V) AC Input Mains Input Doubler PCB
FP602 (1A, 250V) DVD Power Supply Mains Input Doubler PCB
here are some links to guide you:
http://www.electronicrepairguide.com/how-to-test-a-fuse.html
http://www.dinosaurelectronics.com/Test_Fuse.htm
hope these helps,
thanks for choosing fixya for assistance!
Aug 25, 2012 | RCA HD52W59 HDTV Projection Television
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Can I use a thermal fuse from Radio shack in place of the FL231 micro fuse? the thermal fuse has a 250vac with a max current of 10a?
I wouldn't. Fuses that expire must be replaced with the same type and rating as the original otherwise your safety may be compromised.
Mar 03, 2011 | RCA R52WM24 52" HDTV Projection Television
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at Ebay.com.No,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
Convergance is off
I have an RCA 52” HDTV Model R52WM24 the other day it developed a convergence problem (The picture took on a 3D effect and it the screen had an hour glass type of shape)
This appears to be a common problem or a pattern failure.
I wanted to confirm that I did find the fuse p/n FL231 to be blown.
I think it said the RCA part # is 259213 and it is a 400 ma, 125V fuse, Looks like a square capacitor by the fly back xfmr.
I bought a generic part from Digi Key and it seems to be the identical replacement part to the fuse that was in the circuit.
The Digi-Key part is part # WK4440BK-ND (99 CENTS EACH).
THIS IS A 125V, 400 MA ( 0.4 A FUSE). Digi Key PHONE # IS 1-800-344-4539
I am watching the TV right now for last 3 hours and it seems to be a good fix.
The fly back transformer solder connections looked good but it is recommended to re solder these part ( so I did).
Good luck
Dec 27, 2009 | RCA R52WM24 52" HDTV Projection Television
Our TV picture is bowed inward and lettering is 3D. How do we fix this problem?
Go to Menu then to setup if you do not see Convergence in the menu then you have a blowed Fuse FL231 it will be on right hand side of FBT flyback Transfomer there is 3 in a roll it will be the Middle one they are small brown rectrangler Looking caps but are Fuses Located on the Deflection board Bottom Left hand Board.
Dec 24, 2009 | RCA Televison & Video
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
Fusible link keeps blowing out , shutting tv off
Arynsunn,
Thanks to you, I was able to find the solution to my problem.
Have you tried using the correct Fusible Link? I noticed in another post that you said you replaced it with a 500ma instead of the 400ma. I had the same original problem as you and found the exact fuseible links at www.mouser.com. Part# 576-3960400000 Littelfuse Fuses - A 125V UL TL LL .400A . They are only 55 cents plus shipping. I bought 5 for under $10 shipped. Only took 2 days to get them. My TV works like a charm now! I too thought I may need to replace the IC's but thankfully my TV is working fine. If you did need to replace them, where were they located? I couldn't find any stk IC's inside either and the IC's on the heat sinks are all small. Just trying to be proactive, in case I ever need to replace them.
Jan 05, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
275 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
