Question about IBM ThinkPad A22m 2628 Notebook
My laptop doesn't start when i turn on it
I have a Thinkpad A22m, when i turn it on , it doesn't start, but the fan does. And the fan doesn't works when the computer , at last start. when the computer is working suddenly it freezes
  • 3 more comments
  • Leopoldo G?mez Jun 22, 2007
    Hi compuguy, thanks for your attention,whe i turn on the computer, there is a led on on the keyboard, specifically the 5th led from left to right. thats all that it does, it doesn't start, thanks for your help
  • radio109 Nov 27, 2007
    IBM A22m laptop starts up but freezes before OS opens. Also, sometimes suddenly just cuts off.
    Have gone through reinstall of OS (Win2000), that haven't changed anything. Restarted through the safe mode, frozen at Windows starting up stage. Made sure all acessible parts are tightly in place.
  • Anonymous Apr 08, 2008
    my laptop thinkpad A22m wont turn onn
  • outlaw_lyd Aug 20, 2008
    My laptop will start but after a few minutes it just shut off. I have replaced the fan and checked it inside and out. It doesn't matter if I am on the net, in a program or whatever. It just shut off and all I can do is turn it back on and within a few minutes it shuts down again.
  • Bigger Dill Dec 07, 2008
    IBM TP A22M
    On starting with AC power. No.1Hard drive light stays off No.234 on then off
    Leaving No.5 on. Slight sound for 4 - 5 seconds.
    Starting up with out AC Power Battery only all 7 lights.
  • 432 Answers
Are there any lights that come on? Be more specific with your problem. Ray CompuGuy44
Posted on Jun 21, 2007
SOURCE:
Cant find sound drivers for IBM ThinkPad A22m 2628 PC Notebook for XP
You could try this link.
http://www.notebook-driver.com/thinkpad/ibm-thinkpad-a22m-2628-windows-drivers-software/
Jan 15, 2013 | IBM ThinkPad A22m 2628 Notebook
Thinkpad A22m 2628-3SU laptop premature shutdown
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 18, 2012 | IBM ThinkPad A22m 2628 Notebook
IBM Thinkpad A22m works fine except it freezes every once in a while and you have to re-start it for it to work as it is non-responsive to to anything you do unless you do re-start it.....any...
check for virus threat.may be a virus .check also if it freezes at the same point and at the same timing.
may be bad sectors or may be corrupt OS
Sep 07, 2010 | IBM ThinkPad A22m 2628 Notebook
To start an ibm tnhikpàd a22m the pc do nothing, the screen turn to a black screen with a white lock, ask the supervisor or bios password, help
take it to a laptop repair person so they can get into it and reset the bios password. Usually envolves jumpers on the motherboard which is not an easy process in a laptop
Apr 01, 2010 | IBM ThinkPad A22m 2628 Notebook
A22m wont start
hi,
welcome to fixya,ok as u said that its been freezing up,and it is being freezing up all the time,what u have to have to do is that just run the scan of virus removal but u can log into the safe mode and then try and run virus scan and then try and turn on the computer and also try and do the msconfig and restart the computer from safe mode,it should work...goood luck...pls rate this solution....
Feb 16, 2009 | IBM ThinkPad A22m 2628 Notebook
Ibm thinkpad a22m turns on, but no screen
diid u change memory or something it means that some hardware is not compatible or broken lik memory mostly it because of that
Feb 13, 2009 | IBM ThinkPad A21m 2628 Notebook
Need sulution for fix Laptop IBM A22m
try an externial mon. if you have display. this could mean the inverter may be bad. try that and see if it works.
Nov 27, 2006 | IBM ThinkPad A22m 2628 Notebook
IBM ThinkPad A22m 2628 Notebook Logo
247 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
