Question about Toshiba 50H72 50" Rear Projection Television
Hello, I Have a Mitsubishi WD-62725 (62") DLP rear projection TV. Ever since I changed the lamp the last time, the picture is jumpy when I turn it on, with all kinds of imperfections. It slowly goes away, but the imperfections (like video static noise) remains, although to different extents each time. I tried the following: 1) changing the lamp back to the previous one, 2) buying another lamp, 3) opening the TV from the back and making sure that the lamp connection is solid. Nothing works. Any ideas?
  • arup_hm Jan 18, 2009
    I appreciate yor response very much. A FixYa expert (I paid for this one) told me that it is the Color Wheel. Could you pleas comment on this? Thanks..
    Sergeant:
  • 233 Answers
This is a problem with bad capacitors on your FMT board inside the tv.. Not exactly a "do it yourself" type of repair unless you are very good with soldering and have electrical repair knowledge.
Posted on Jan 17, 2009
  • Josh Crager
    Josh Crager Jan 19, 2009
    Well, to tell the honest truth, these particular sets are RIDDLED with problems from what I have seen. Bad color wheels usually come with a symptom of a screeching or screaming sound coming from the set... However, these tv's used sub-standard Jamico capacitors and they regulary fail in the power supply, dm module, and fmt board.
    I would almost recommend fixing it if you can get it done for around 300.00 , but once you get it fixed...sell it!
    I have one of these sets sitting in my garage that I am still trying to justify fixing myself for use in the kids room...but with the commonality of problems and the cost of the fmt board, I still cant see spending the money and labor on..
I have to change the lamp on my mitsubishi dlp tv. where is the lamp located?
Here is a link to the owners manual for lamp cartridge replacement. Specifically go to page 65 for instructions. Good Luck : )
http://support.mitsubishi-tv.com/files/oguide/WD-52327.pdf
Jul 26, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a 65 inch DLP and when i turn it on i get no picture and just the sound of static comming out of the front tv speaker, no actual audio from the cable box. When looking near the bulb box i see the...
When was the last time u change the projection lamp?If u watches tv at lest 4 or 5 hours a day and the projection lamp has not been change the last 1 1/2 or 2 years.This problems happen alot,when the projection lamp life is over.Change the projection lamp.
Sep 03, 2010 | Mitsubishi WD-65731 65" HDTV
Do i need to change my lamp? or is something else?
is your tv a dlp?
maybe it can be you tv lamp..
need to know first.
Jan 25, 2010 | Mitsubishi WD-62525 62" Rear Projection...
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
How does tv know when lamp is expired -changed bulb after yellow lighht came on but light stayed on months later the light went to red and tv wont turn on
When the lamp goes on a DLP you get no picture, if the light came on and you still had a pic then it might have been telling you ,you had other problems. If the TV wont come on now check your bulb it might be blown this time. The bulb will have lots of small peices of glass in it when its blown. They should last a few years each (3-4).
Jul 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV WD-62525
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info www.ctechnicians.com
Dec 10, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
158 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
