Question about Cyberhome Televison & Video
Freezes in the middle of playing a dvd
. We run a cleaner cd, but it doesn't really seem to help
  • lnjrfrasch Jan 17, 2009
    it stops after playing 20 to 30 minutes,into the disk and different times after that. and on professionally recorded disks. sometimes it starts again on its on, sometimes we fast forward, then rewind and it plays ok for a while.
    Problem Solver:
  • 6 Answers
1. You say in the (middle?) That in itself is subjective, Does it stop at an 'exact' specific point after playing for x number of minutes? Is it the same point for any DVD being played, or does it stop at a random point? - Does it stop when playing DVD--R or +R or what type of Disc? - more details helps to find a solution.
Also it is never necessary to use cleaning discs - Do that and it will wreck your player - and may never read a disc again. Using cleaning discs could have caused your problem. Use cleaning discs only for practicing how far you can throw them.
Posted on Jan 17, 2009
  • Arsenal Jan 17, 2009
    I will get back to you on that one within 24 hours
Why my laptop DVD player freezes suddenly while playing, just on some certain CDs or DVDs even the same CDs or DVDs works properly in other laptops and PC?
Seems your laptop DVD player's laser diode lost it's capacity. If it is not that old, try the followings:
1. Blow some air with a watch air blower or an air can. Try the DVD/CD which freezes. If this doesn't work
2. Put a drop of lens cleaner and wipe with caution to the lens. Wait for a few second and try playing the DVD/CD. Don't use force when cleaning the lens. This should be just touch and wipe action.
If this is not the case and the drive is old, you need to replace the drive. This should cost about 30$ to 45$. I did mine last month.
Good luck
Jun 11, 2014 | Dell Inspiron Computers & Internet
My handheld dvd player isn't reading the disc-they just spin really fast
Spray an small drop of safe window cleaner onto a Q-tip. Clean the laser lens carefully and then use the other end of the Q-tip to dry it. Use compressed air on and around the laser lens (do not blow on it). Clean your DVD disc and try again. If it fails again, try using a CD, if it will play a CD and not a DVD your optical pickup assembly is defective. If the CD wont play at all, your optical sled or spindle motor and/or drive is defective.
Most cases if cleaning doesn't fix it, it's cheaper to replace the entire DVD player. All portable DVD players are junk, regardless of brand.
Jul 18, 2011 | Video Game Consoles & Games
I HAVE A LG HT506 DVD PLAYER AND WHEN I PLAY ANY DVD IT PLAYS FOR A SHORT TIME THEN THE PICTURE FREEZES . IF I LEAVE IT FOR A SHORT WHILE IT STARTS PLAYING AGAIN THEN FREEZES ONCE AGAIN CAN YOU HELP...
By your description it sounds like the DVD player needs to be cleaned. You can purchase a CD/DVD cleaner at most places like Walmart, Target, or Radio Shack.
Try cleaning it first. If that doesn't work, it will probably have to be repaired by a professional, if it's not under warranty.
Jul 13, 2011 | LG HT503TH Theater System
Jensen flip out head unit volume knob doesn't work . the remote works fine but just that one problem.. and i cant seem to get the DVD to play.! ( bought it used..)
it needs to be serviced by jensen or some other repair facility. there is nothing you will be able to do to get the knob to work. if it plays cd's and not dvd's thats also an issue that you can't fix by yourself. if it doesn't play cd's or dvd's then you can TRY to run an optical cleaner through it. its a cd player cleaner kit you can get at most electronics stores.
Mar 17, 2010 | Jensen's VM9312 Car DVD Player
TheCD or DVD freeze
buy a DVD lens cleaner
Note DVD LENS cleaner, NOT DVD Cleaner the latter is for the discs, not the player
A second option is to remove lid from your player and gently swab the lens with a cotton bud or similar soft lint free product.
This may not be for the faint hearted, its not a $30 DVD player but BOSE so may be something more suited to a hi-fi repair outfit.
The lens will be really obvious as it faces upwards and looks like a small round clear glass bead.
Make sure its unplugged too!
Mar 03, 2010 | Bose (321GS) System
Mintek dvd 1600 freezes while playing cd
First use a dvd lens cleaner its a cd with small brush at the bottom,
This will clean the optical lens.
If it still freezes while playing cd it might be the optic lens was damaged and need replacement.
Dec 13, 2009 | Mintek Televison & Video
Hi, am Mr.Varghese. I have LG dvd which is 1-2 yrs old. Problems are:- 1) DVD - not playing at all 2)VCD - Playing but stucks after 3-5 mins 3) MP3/Audio CD - Afer 1 song is over it restarts from the...
Hello Mr. Varghese,
Your LG dvd player's lens might need cleaning. It is having a hard time reading those cds that is why it sometimes skips or just stops in the middle of playing them. Does this happen also to new cd's? Sometimes cleaning those cds helps the lens reading them.
If you have a disk cleaner, you can run that for 30 seconds on your player. It that does not help, then you might need to open your DVD player's casing and clean the lens manually by opening your player, get a soft cotton earbud and damp in an alcohol and gently wipe your dvd's lens. Then try to return back everything and test playing cd.
Sep 25, 2009 | Televison & Video
My ps3 freezes in the middle of games and movies. And sometimes it doesn't even play the movie.
Hey guys i had this same problem 2 times the second time being tonight and i fixed it both times! I don't usually post on forums but im just trying to help out here i know it can be really frustrating when this happens. Anyways what i did to fix the problem is lift the ps3 a couple inches off the ground and gently drop it so the dust or w.e it is in the ps3 settles n fixes. The second time this happened (tonight) i tried dropping it again and it didn't work, it really got me mad, but then i tried dropping it again this time upside down and after 1 drop it worked. anyways hope this helps :)
If i am helpful to you, please rate me.
Aug 11, 2009 | Sony PlayStation® 3 (80GB) Console
DVD problem
It could be a couple things...
#1. Over time, dust and deposits can accumulate on the laser that reads the disc. In many cases, DVD players with this problem can still read CDs. You could try a DVD laser cleaner, which is usually a disc that has a tiny brush glued onto it. Run the cleaning disc 2 or 3 times, and try it again. Try both CDs and DVDs, since CDs are easier to read than a DVD.
2. After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. In many cases, DVD players with this problem will still be able to read a CD. I'd try a cleaning disc first, since the only way to fix this problem is to bring the unit to a service center for repair.
Let me know what happens after you get the DVD laser cleaner and run it. Hope this helps.
May 07, 2008 | Televison & Video
Televison & Video Logo
210 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
