Question about Presto HeatDish Compact Heater
PrestoPresto HeatDish Parabolic Electric Space Heater Plus Footlight
I bought one of these last January and LOVED it...one day I went to turn it on and nothing...the buzzer works but it has no heat...how can I fix this...or where can I begin to look..thanks!
  • guiermofour Jan 05, 2009
    My Presto Heatdish turns on at MAX heat no matter what the control knob is set to. How can I fix this problem?
  • My Presto Heatdish has noise time after time after turn on. How can I fix this problem? Thanks.
Posted on Nov 06, 2009
  • 75 Answers
This is most likely due to a break in continuity of the heating coil. Most of the time this happens at the connection box. To trouble shoot, first ensure that the POWER IS DISCONNECTED. Open the area where the power connector goes into the heater and look for the terminals for the heater. IF the heating coil leads are broken or burn, clean that area and reconnect the ends to the terminal. If the terminals look OK then you will need a multimeter to check for continuity in the coil.
Posted on Jun 22, 2007
SOURCE:
My Presto HeatDish Plus keeps making an abnormal clicking sound (at a low setting, turns on then off without any sort of pattern). There is also a bright streak of light that appears at the back of the...
I have the same issue. I am worried that this could be a problem and this spark might start a fire. Does anyone else have it too? or have an opinion abou that?
Dec 31, 2010 | Presto HeatDish® Plus Footlight® Electric...
I have a HeatDish plus footlight. Worked fine for a while. Light went out, but the buzzer still worked when it was tipped so no big deal. Then it quit. I have taken it apart and note the contacts are...
Got the same or almost the same issue, no light (burnt out). I bypassed the temp switch on the top by taping the contacts together and it works, so I'll presume the problem is in the temperature switch. It worked fine last I'd used it so I don't know why all of a sudden it won't work presumably due to the temp switch.
I'm going to call to see about parts tomorrow, then decide whether to fix it or just replace it. I don't feel I've had reasonable usage out of it, so won't likely buy the same IF I can't fix it.
Theses are a simple device, almost like a toaster in complexity, so it's kind of amazing it didn't last longer than it did.
Nov 17, 2010 | Presto HeatDish Compact Heater
Costco Presto Heatdish
No repair is economically viable now, sorry need a new one.
May 24, 2010 | Presto HeatDish Compact Heater
Where can i locate the on/off machinism for the presto heat dish?
Handy top-mounted thermostatic control maintains the desired temperature automatically plus it has a special safeguard features turn the heater off automatically in case of accidental tip-over. Because of this technology they eliminated an on/off switch. You have to unplug it if you want it to be totally off. sorry
Mar 19, 2010 | Presto HeatDish® Plus Footlight® Electric...
Buzzer goes off
This was the answer from Presto as I had the same problem. Cleaned it with window cleaner and a wooden spoon and paper towels and now it works great!
Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Dec 29, 2009 | Presto HeatDish Compact Heater
My heater makes this constipating noise and the "tilt" alarm goes off after 10 minutes. I'm never able to turn it to the high position.
This is the answer I got from Presto. I cleaned it with window cleaner, wooden spoon and paper towels. Dish works great now.
- is tipped
Dec 12, 2009 | Presto HeatDish Compact Heater
No heat
since the light is on its own circuit this dont surprise me at all. The most likely cause of this is the contacts on the inside of the heater. the wire inside of the unit is very small for a heater, bad design, and is conected by spade conectors. my wire in mine burnt through and did the same thing. I bought some good thick wire and rewired the unit direct and this seemed to fix the problem. If you need further assistance check out some of my other solutions in this same area.
Oct 17, 2008 | Presto HeatDish Compact Heater
Presto HeatDish Plus Footlight - Parabolic Electric Heater Where can I find these??? They are great.
http://www.gopresto.com
Or try a thrift store for a used one. Do a search for "heat dish" without the quotes, and you will get a few hits. Amazon.com has a few of this type of heater.
Aug 18, 2008 | Heating & Cooling
Rheostat vs. Thermostat Temperature Control
yes, it should work. Just ensure your rheostat will handle up to 1500 watts at reasonable settings. A better approach is a 1500 watt pulse-width modulator circuit that draws little power itself. these are available where power tools are sold (like harborfreight.com and known as speed controllers. I use one for a large air fan in my garage.
Nov 04, 2007 | Presto HeatDish Compact Heater
Presto HeatDish Compact Heater Logo
747 people viewed this question
Top Presto Heating & Cooling Experts
Vish Iyer
Vish Iyer
Archie Ferrarini
Archie Ferrarini
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
