Question about Logitech (9252770403) Consumer Headset
Wiring pulled loose from earpiece
Logitech deluxe laptop headset wiring diagram needed so I can re solder connection for earpiece and microphone. Thanks
  • 5 Answers
SOURCE: Logitech USB headset no sound
Have you tried changing the Audio Device that windows is using?
Under the Sound and Audio Devices in the ontrol Panel. Under the Audio tab, try the Default Device under Sound playback. Change this to the headphones.
Posted on Nov 10, 2007
SOURCE: i have a logitech vantage
how can i hear others loudly in earpeice?
Posted on Oct 26, 2008
SOURCE: Logitech 350 Headset Casing
Had the same problem, no headphone speakers would work.
First use a flat head screwdriver and insert in between leather padding
and plastic case and pry apart. Best to start at one area, insert a wedge
and pry further along. It will take a bit of force before it pops apart.
Take out 4 small philips screws
I found that the wire had broke right at the entry grommet. I pulled the
wire through and wiggled it and the speakers went on and off.
In my case I felt it was best to redo all the wiring. I first took these pictures
to have a map and pulled through an extra 4" of wire through and cut/desoldered
the wires.
Here are the original wiring connections at the speaker
4017e98.jpg and what must be the common. This was the wire that was broken
inside.
I re-soldered all the connections and separated them as best I could with
electrical tape (no shrink). Put everything back together and so far
seems to work fine.
Posted on Dec 23, 2008
SOURCE: I get no sound and my my microphone doesnt work.
man this is all **** i got same problem no one knows how to fix !!!
Posted on Jun 29, 2009
SOURCE: Logitech USB Gaming Headset only working out of one ear
I've had this happen twice with Logitech headsets and believe it has to do with the cheap/fine wire they use in the cables. I suspect that a good tug on the cable will snap the wire or some other internal connection.
Posted on Jun 18, 2010
Logitech headset usb wiring diagram?
Is this what you are looking for?
Jul 10, 2012 | Logitech USB HEADSET H390
Wiring broke for all five wires in the usb connection of a Rosetta Stone Head Set 20090205. I may be able to re-attach. Where do the wires go on the usb plug?
Open the plug case by prying it apart.
The tiny circuit board is labelled on one side - three connectors for the headset and two for the microphone.
G - headset ground - red/gold wire
R - headset right - blue wire
L - heasdet left - red wire
M+ - microphone + - green wire
M- - microphone - gold wire.
Use hot soldering iron to 'melt' off the tip of the wire coating and apply tiny amount of solder. Place wire in position and solder together.
Finally use electircal tape to hold the plug covers together and continue to tape along the cable so it will not pull out again.
Jan 17, 2010 | Rosetta Stone Spanish Level 1-2-3 Full...
Can someone provide a wiring diagram for the
hello, my name is paul and wondering if you can help me with a wiring diagram of cool talk throat mic icom earpiece, hope to hear from you soon .
kind regards
paul
Dec 05, 2009 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Aug 25, 2009 | Logitech Premium Headset
Broken wire on headset
Friend you need to use a electronic tester and a slodering iron. just solder the cut wires and test if it has connectivity
May 28, 2009 | Logitech (174040) Consumer Headset
Broken wire to my microphone on my lifechat lx-3000
You cant wire then directly there is a USB D-A chip that controls the headset converting to 1/8" mini plugs may work one for the mic and one stereo plug for the earcups
Mar 30, 2009 | Microsoft LifeChatâ„¢ LX-3000 Headset
Wiring diagram for accessory plug needed.
I am looking for the same wiring diagram. The headset Moto sells is a single earpiece with microphone, so how does that end up being a stereo connection Neto? Just curious how, or is there also a full headset with microphone? ( I dont' know, just asking)
Would this be a 4 ring TRS connector? Sleeve = ground, then left, right, and the tip as the microphone??
Jan 18, 2009 | Motorola Talkabout T5420 (14 Channels)...
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Wiring diagram
http://www.performanceaudio.com/media/pdf/54/3429_b.pdf
That should shed some light...might have to through solder on to the circuit board should be relatively easy!
Sep 13, 2008 | Crown CM-311A Professional Microphone
Radio Communications Logo
284 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
