Question about Samsung Televison & Video
Samsung Flat Screen TV HDTV 1080i
Everytime I push the power "on" , I hear it turning on and audio coming out but no picture. After about 5 seconds it shuts off automatically. What is the problem? What are the solutions to fixing it?
  • 11,896 Answers
Lets try something ,turn the set on and put you forearm in the face of the picture tube if your hair stand to static it means you have high voltage and your set is missing possible the screen or filaments volts,if the hair in your arm does not stand your set is missing the high voltage and the problem is related to the flyback but it does not mean is bad ,it could have a loose conection in one of the legs or in the near area,next time it happens tap on the side of the set to see if it reacts if it does you know you have a loose conection.If you are familiar with tv service this will be a good place to start but if you are not too familiar be safe and call for assistance from a servicer.Let Us know if you need more information and how it goes.
If this does not correct the problem. Then it is most likely the power supply board.
Posted on Jan 17, 2009
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
I have a Samsung 42 inc HDTV 1080i Model: TXN3271HFXIXAA WITH NO PICTURE AND NO SOUND ALL YOU HEAR IS A TICKING SOUND. Can you please help. Thanks Phil
Are you trying to watch a dvd or device through the TV, or just watch through the TV's built in tuner?
Hope this helps
TV_Doctor
Jan 03, 2011 | Samsung 52 in. LCD Flat-Panel HDTV
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Black boarder on screen of my samsung hdtv 1080i
You may have to change the aspect ratio but doing so may change the picture quality. Your owners manual should explain how to do this. If you don't have the manual you may be able to download it from Samsung for your particular model TV.
Nov 15, 2009 | Samsung 37 in. Flat-Panel LCD HDTV
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a HDMI cable hooked between my Direct tv DVR receiver and my Samsung flat screen HD plasma tv. When I turn to Direct tv channels 100 or 200 the screen begins to flicker. My tv is 1080i. This is what...
If the TV just Flickers for a few Seconds then the Picture is Good and Stable, That is just the HDMI re-syncing often due to different signals from 480i to 1080i being broadcasted. If it continues to Flicker then check the options for Video set-up in your DTV menu. Make sure all available resolutions are checked to display or select AUTO if possible. TIP: NEVER Unplug or Plug in HDMI cables with the Power ON. This can Short out the HDMI Input leading to a Repair. Turn off All Units then plug in your cables, When ALL are in then hit the Powers.
Apr 28, 2009 | Denon AVR588 Receiver
2003 Samsung HDTV 1080i 42" wide screen has just developed picture problems distorted and red. Almost looks 3D. MODEL NO.:HCN4226WX/XAC SERIAL NO.: 37083CEX400297E
This is a convergence problem and can easily be fixed either by resoldering the pins on the convergence ICs or by replaceing them if they prove to be defective. Can you solder? Do you feel confident in replacing these parts?
Keep us posted.
Dan
Jun 04, 2008 | Televison & Video
Tv problem
have the power supply checked out it may be weak
Oct 04, 2007 | Samsung PCH521R 52" Rear Projection...
Televison & Video Logo
77 people viewed this question
Henry  Thomas
Henry Thomas
