Question about Indesit W 123 Front Load Washer
Indesit w123 water fills up ok but a bit slow but when its gets to the softener it has stopped taking it as the draw was still full of my softener liquid. ive checked all the pipes and taps etc made sure there are no blockages. i usually use the no 8 programme and i can't figure out what's the matter with it. anyone got an ideas??
    Sergeant:
  • 236 Answers
The holes above the drawer may be blocked. remove the drawer and scrub the holes with a stiff washing up brush rinse away then try again.
Posted on Jun 23, 2007
SOURCE:
When I clean a salt bridge from my softener how much water should I put back before putting my salt in?
You don't have to put in any water. The softener fills itself when it regenerates and immediately produces brine. Though it sits for a period of time to soak, that is all it takes. Then using venturi effect, it draws the water out and runs it into the media in the softener. Some water is left in the salt basing but that is ok.
Oct 01, 2014 | Dishwashers
Softener wont add
Please ensure the machine is turned off at the power socket before you do anything.
Have you tried removing the draw? If you pull the draw out on most washers and slightly tilt the draw up and then try and pull further out the draw will come out. (DO NOT USE BRUT FORCE) if it doesn't come out easily then it probably isn't designed to.
If you get the draw out give it a really good wash in hot soapy water, the compartment where the softener goes normally as a piece of plastic that lifts up so you can clean the compartment throughly. Whilst the draw is out also give the inside of the draw compartment a clean out. (PLEASE ENSURE THE POWER IS OFF) Just for safety.
Once you have cleaned the draw replace it and try a full wash and see if that cleared the problem.1_15_2013_10_08_16_pm.jpg
Jan 15, 2013 | Belling SGE12X Front Load Washer / Dryer
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
I have an indesit 1100 washing machine, but it does not take the softener in from the draw. i have cleaned the draw out nad tested the draw over the sink. it seems to work ok but once its back in the...
You need to clean the drawer box top, the holes get blocked and the pressure is only low on the conditioner section..you will need a lengthy object to clean the hole properly
Oct 05, 2017 | Indesit Washing Machines
The fabric softener compartment of the detergent drawer is not emptying. The machine is an Indesit W123.
I have had my machine for the past 6 years, I do on average ten loads per week, and it has never failed me. A bit noisy but for the price I could n`t complain. I have just broken the door handle which has cost me a total of #8.50. Not bad for six years hard labour
Dec 04, 2009 | Indesit W 123 Front Load Washer
Water in softener compartment Indesit w101 (not above)
Go to Indesit web site download user guide
http://www.indesitservice.co.uk/hs/pages/manual/manualSearch.do
Most soap drawers have a plastic latch which needs to be pressed to release it.
You will find that there is a ball of soap congealed in the back of the dispenser drawer
May 25, 2009 | Indesit W 123 Front Load Washer
Indesit washer w123
take soap drawer out and clean it
Aug 28, 2008 | Indesit W 123 Front Load Washer
Indesit w123 front load
would check pressure switch and the pipe that goes down to the drum for blockages if not may be faulty water valve unplug first regards jason
Apr 28, 2008 | Indesit W 123 Front Load Washer
Indesit 1200 washer/dryer instructions
probable cause is just poor water flow from outside. switch water off. undo hoses and check not kinked. in each hose, there should be a gauze filter. clean this. look inside the valve spigot and check no dirt buid-up. put hoses in a bucket and check water flow is ok. remove drawer and check holes in top of box are clear
Jun 14, 2007 | Indesit WA 115 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
142 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
