How to replace cartridges in my Canon MX700. What sequence of colors: I know Black is on left what comes next and third and fourth? Thank you
  • fishinoso Jan 17, 2009
    Thanks a million, Eric Brunswic--you saved me a beating from my wife!!!!....fishinoso
    Scholar:
  • 88 Answers
I have the same printer. The ink from left to right are Black, Cyan, Magenta, Yellow.
I hope this helps,
Eric
Posted on Jan 17, 2009
  • Eric
    Eric Jan 17, 2009
    I'm really glad, I was able to save you from a beating.
    Thanks,
    Eric
I have a Canon MX700 and suddenly I began to have problems with the color. I am using Canon ink cartridges but all my color jobs come out with only blue and black, no magenta or yellow. Every time I run...
This worked for me:
Unplug (not just turn off) the printer. Wait at least 20 seconds, then plug it back in. Hold the Feed Switch down, then turn on the printer (continue to hold the Feed Switch down). When the printer finishes cycling the paper feed, release the Feed Switch. Copy anything and it should print. You're good to go.
Oct 01, 2013 | Canon PIXMA MX700 All-In-One InkJet...
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
How to refill pixma mx700 magenta ink tank without
The colors are individual. That machine takes the Canon CLI-8. I would suggest reading your manual on what the procedure is for changing the ink cartridges out, it typically varies slightly by machine. There should be an option somewhere one of the menus to change the ink cartridges. When you buy a replacement be sure you buy from someone who isn't trying to scam you. I would recommend Cartridge World, of course, or OEM. Do not use cheap online cartridges, you will only have headache later.
Feb 15, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I use my MX700 only for black & white matters. It sometimes refuses to operate, informing me that my color cartridges have run dry. How do I overcome this?
Unless you have chosen to print in "true black" where only the black ink cartridge is used, your printer automatically will use some inks from the color cartridge to make black. (The reason given is so that your color cartridge will not dry out and cease to function when you do need it for color).
You did not provide your operating system. If you can find your printer name listed in "Control Panel" (usually in "Printers and Faxes"), right click the name and choose "Properties". See if you can find an option to print only using the black ink cartridge.
I hope this helps!
Dec 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Can I use only black ink cartridge with the MX700? All other colors removed?
Canon printers won't let you do that, all colors have to be installed and not empty, for it to do anything. If you ran with colors removed the printhead would dry and plug and require replacement.
Nov 20, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Wont print black
Change the black ink cartridge.
Jun 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Black ink out--can I print in color instead
first go to the control panel,second click on printers and hardware,third click on printers and faxes.fourth highlight your printer,right click on it.fifth,go to properties,and then click quality.you should be able to change it from there.good luck,hope i helped
May 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Print in black if color cartridge dry?
If it was me, I would fill the color cartridge with black ink. This then fools the printer into action. Of course, it would be unlikely that you could use that particular cartridge for color again. Good luck.
Apr 10, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer Pixma MX700 will only print in color not black and white?
Try going into Control Panel and click on printers. Normal 0 when the next window comes up, Click on MAINTENANCE, the Properties page will come up and this is where you can do the NOZZLE check/clean and other functions. The NOXXLE is more than likely clogged from lack of use and needs to be cleaned. It might take several times to clean it. Hope this helps. Bud
Jan 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Mx700 only printing in B&W
This is a software problem, do uninstall and re installation of the printer software on your computer and that should do it...
Dec 14, 2008 | Canon MX700 Office All-In-One InkJet...
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
