Question about RTO Waste King AH-780-UL Quick&Hot Instant Hot Water Dispenser - Tank Only
Brand new Waste King "Quick & Hot Instant 190 degree hot water dispenser. Properly installed unit does not provide hot water. Water lines are correct. Power source is correct. Have followed instructions for automatic heating unit reset procedure. After installing the unit, filling the tank, checking for leaks, running cold water through the unit, and finally plugging the unit in and waiting the recommended time for the water to heat up, cold water is the result. Do I have a factory defective unit or is there some trick that the instructions do not reveal? Help!
  • 90 Answers
I would contact the Anaheim Manufacturing Company, that makes the Waste King Quick water heater. You can also go on-line @ www.wasteking.com and check out their site for a solution.
Posted on Jan 22, 2009
2 Suggested Answers
SOURCE: Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
Posted on Mar 19, 2010
Waste king 1001 disposer is jammed and won't rotate from inside with a broom handle. Do I need to take it apart to free it up?
Should be a place on the bottom of the unit to insert a hex or allen key to turn it to break it free... if its jammed. Make sure power is off/ disconnected prior to performing this task.
Aug 14, 2013 | RTO Waste King AH-780-UL Quick&Hot Instant...
5 year old Waste King AH-780-UL Quick&Hot Instant Hot Water Dispenser produces white residue in the dispensed hot water. What is causing this; what remedies are recommended? i took out faucet and the...
well the tank is made of brass and copper. That takes away that it is the unit. It sounds like lime buildup. Now what does happen as water goes into the tank and heats up lime will remain in the tank. Then as time goes buy it then starts to get to heavy and relesase itself and then the clog effect it taking place.
the best thing you can do now is reverse flow water into the tank and wash it out, its call beack washing. Yu can buy some products to put in at first to help break it down and then you get ore out.
With the new whole house units they now install a vakve set that has two way valves so you can backwash the tanks and stay ontop of the lime.
You must be asking where does the linme come from, well it starts at the well where the water department gets there water. then it goes into a filtering system and they use a lime to act as the filter agent then it heads out to the system and coats the pipes all along the way. I have cut 16 inch pipe and there was solid inch of lime caked inside.
I tell many people if yuo looking inside the water system yo would never drink the water. You might want to think about getting a whole house filter system to slow down the kime that geets in.
Thanks so much be safe in all that you do.
Yom
Hey, take a second and rate our service this way we know if we are doing a good job or tell how we can do better:)
Sep 11, 2011 | RTO Waste King AH-780-UL Quick&Hot Instant...
Water leaking from bottom of quick and hot dispenser only 18 mos old
I had the same problem. There is a 2 piece metal tank inside. The top and bottom of the tank are connected with screws & nuts, and there is a rubber o-ring between the two pieces. The grove for this o-ring is very shallow and it doesn't fit tightly, increasing the probability of misalignment during the assembly process. I was unable to fix the leak, IMHO the grove is too shallow and the o-ring is not thick enough. I decided it was poorly designed & trashed the unit.
Aug 26, 2011 | RTO Waste King AH-780-UL Quick&Hot Instant...
New Westbrass water dispenser does not have the lines marked "red" or "blue" as described in the directions.
This faucet is the hot only version so it has two copper lines and one Santoprene rubber line. The copper line directly under the handle is the inlet from the wall - the second copper line attaches to the hot water tank by the corner. The Santoprene line attaches to the middle of the hot water tank. This faucet cannot be installed without the hot water tank.
Jun 13, 2009 | West Brass NEW Oil Rubbed Bronze Instant...
Slow leak drips from bottom of 4 year old model
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Apr 07, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
You can probably repair this by removing the fittings and replacing any plastic compression rings with new ones. Everything else can be cleaned with grade "0000" steel wool. This will get rid of any deposits without damaging the surfaces. ! or @ careful wraps of Teflon Tape to the MALE threads will help get a good seal.
Feb 04, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Jan 17, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Leak from hose that connects the dispenser to the tank
the temp is to high and it is just a neoprheme hose go to the hard ware store and purchast a new hose the samt size 3/8 re install it and trun the temp down on the unit, make sure the hose you get has at least 140 degree rating
Dec 26, 2008 | Mountain Plumbing Mountain The "Little...
RTO Waste King AH-780-UL Quick&Hot Instant Hot Water Dispenser - Tank Only Logo
746 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
