Question about Siemens Gigaset2420 Cordless Phone
2420 Gigaset call waiting answering machine
When I'm on the phone my calls that come through on call waiting are not going to my answering machine. My customers say my phone just rings and rings. How do I fix this?
  • Anonymous Mar 14, 2014
    symphony 2210 digital cordless telephone with answering machine.wont accept incoming calls from mobile.s different ring tone is heard
  • Anonymous Mar 28, 2014
    How can I hear messages on the answering machine
  • 32 Answers
Make sure the answering machine is turned on for both lines. To check settings: Scroll, using BACK and FWD, to desired setting. 1. Press MENU 2. Scroll to "ANSWERING SYSTEM MENU" then press SELECT 3. Scroll to "LINE 1 SETTINGS" and press SELECT 4. Scroll to "ANSWERING SYSTEM ON/OFF." Check to see if it is set to "ON," as this is the default setting. 5. Exit MENU and Repeat steps 1 thru 4 for LINE 2 SETTINGS. I don't know if you have Acrobat Reader for .pdf files but below is a link to the owner's manual for this phone. If you can, download and look at the bottom of page 79 of 116 for more help. http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052870.pdf Good luck.
Posted on Jun 22, 2007
Is it possible to use a 2420 Gigaset phone in the same office with the 8825 Gigaset phone? Will they conflict/interfere with each other?
No! there should be no problem or issues because frequencies are wide enough that interference should not be a factor.
Jan 08, 2011 | Siemens Gigaset 2420 Cordless Phone
Need a master PIN
To reset the Gigaset 2420 Pin
At "System Settings" in the Menu press *65# then press the Select button.
"System PIN Reset" will be displayed (if the PIN was not already the default).
The default PIN is 0000.
Goodluck..
May 14, 2008 | Siemens Gigaset 2420 Phone
Siemens gigaset 2420 two line phone drops calls
dump the memory by deleting your mailbox and your call log-
Feb 15, 2009 | Siemens Gigaset 2420 Cordless Phone
System pin # reset
There is a way to override and reset... I think you need to press *67# when in the system pin area via menu. Confirm this first though. There is a way to do this though- then you reset it to 0000- google it and you will find the answer-
Dec 01, 2008 | Siemens Gigaset 2420 Phone
Gigaset 2420 Siemens
You may have the wrong or defective power supply. Or, that problem is common from getting a power surge and the unit will probably have to be sent in for repair, sorry.
May 05, 2008 | Siemens Gigaset 2420 Cordless Phone
Siemens 2520 gigaset base
You will need to customize your Call log settings to show which area code your located in so it will redial from the log properly. To do so, push Menu, then scroll to system settings, push select, then scroll to Area Codes, push select and specify the area code that you are in. If you need additional assistance, go to the link below which is the full manual on PDF, then go to page 48. Hope that helps. http://www.barclayent.com/manuals/Gigaset%202420%20Plus_guide.pdf
Mar 21, 2008 | Siemens Gigaset 2420 Cordless Phone
Siemens 825 Gigaset
I have the same problem with mine - a Siemens 2420 base. The calls come in, all the lights flash, then the thing clicks and resets. At this point, it can only be used for outgoing calls. i think i'm going to retire it. Too bad, cause the speakerphone was one of the best ever.
Nov 28, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Nov 14, 2007 | Siemens Gigaset 2420 Phone
Siemens Phone
I just replied to a similar post. This is a common problem, not only with the Siemens but most all manufacturers that used this design of display on many different devices. And in this case, the display connections are pressed on with a special machine and can't be replaced by a do it yourselfer. Sorry I can only recommend sending it in for repair.
Aug 21, 2007 | Siemens Gigaset 2420 Cordless Phone
Line cut off problem
That is a common problem with this model, normally happens after a storm passes through. Unfortunately there is no easy fix for on site, it would need to be sent in for repair or replaced. You can google Siemens Cordless Repair to find service facilities.
Dec 18, 2006 | Siemens Gigaset 2420 Cordless Phone
Siemens Gigaset2420 Cordless Phone Logo
301 people viewed this question
Top Siemens Lands Phones Experts
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
