Question about Whirlpool Duet GHW9150P Front Load Washer
Door was leaking and now it shows error code H F
The door was leaking. We cleaned out from underneath the seal. Now we tried a load, it didn't leak but it start beeping and flashing the letters H F
  • 640 Answers
Hf means no water entering unit,,,make sure that there not water in unit already..make sure your pump is not clogged,,if need be post question how to clean pump or just contact me,,also make sure theres no kinked inlet hose,,and or drain hoses..check and see if your inlet screens are clogged..onthejob
Posted on Jan 18, 2009
Waste water leaking from underneath my zanussi jetsystem ZWF16381
Could be slight hole in door boot seal / or circon pump suspect door boot seal
Jul 01, 2012 | Washing Machines
Water splashing out from under the door
I just had this problem myself. I found calcium buidup on the seal and lip on door where it goes against seal. I took CLR, I think it stands for calcium lime and rust remover and clean it all up. First load seemed fine, although as I was cleaning it I noticed that the seal has shrunk away from the bottom of the machine. So if it leaks now I will be replacing the seal. I might add that a couple of years ago my daughter had the same problem, cleaned the seal, had food particles on it. It didn't leak after that. Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Dishwashers
Hotpoint aqurious leaking at front underneath,concrete block wet at front towards door,alot of water coming out,any ideas thanks.david
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
Feb 22, 2010 | Hotpoint Aquarius WD63 Front Load...
Water keeps filling up under passenger seat in rear of car
My 2001 passat did the same thing. my leak was coming from the door panel. Open your door and use a water hose to simulate rain water running against your window. Water should run into door and drain out of several drain holes at the very bottom of your door. Check for water leaking from the bottom of your plastic door panel. The water runs down into the door and leaks through your inner door panel seal causing water to leak inside from the bottom of your door panel and run into the floorboard instead of draining out the water hole in the bottom of your door.
Aug 26, 2009 | 1999 Volkswagen Passat
Bosch logixx 1600 exoress from leaking underneath approx middle
This video will show you how to change a door seal on this Bosch front loader washing machine
May 20, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking dishwasher
what sort of soap powder do you use
some soap powders foam a lot in machine causing dishwasher to leak through seals
also check that the machine is square that is the door is closing parallel with cabinet
do not use power balls in machine just standard dishwasher detergent and separate rinse aid
Feb 02, 2008 | Dishwashers
Washer Leaking
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process of how to fit and replace
Sep 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Mar 28, 2007 | Kenmore 43042 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal De
