Question about Acer CASE Mid-Tower ATX P4 350W FAN DUCT FOR 915, (4)5.25", (2)3.5", (1)3.5" 24PIN CONNECTOR USB kit COL... (9197120A51)
I have an acer aspire laptop i cant connect my wi-fi is on computer shows one hundred percent signal but wont connec--joe
  • Jay
    Jay May 11, 2010
    Are you saying that your laptop can detect a 100% WiFi signal but you cannot connect?
    Well it could be that the signal your are detecting is encrypted. you will need administrative privileges to join your laptop within that WiFi's domain.
  • 219 Answers
If the Wireless connection you're attempting to access is your own, you will need to take some steps to discover your wireless connection's authentication password. If however the wireless connection you're attempting to connect to is not your own, don't continue reading unless the person who owns the wireless connection has given you permission to connect to their network.
Anyways, the easy way to discovering your router's wireless connection password would be to check the router's manuals for the default wireless encryption password. If the password listed doesn't work when you attempt to connect to the wireless connection, or if you don't have a manual, try the hard way...
The hard way requires you to directly connect to your router via a CAT5 (Ethernet) cable. Afterward follow these instructions for gaining access to your router's control panel:
Go to Start>Programs>Accessories>Command Prompt. From here type in: ipconfig
PressENTER to execute the command. A list should be returned listing some IPAddresses. Look for the one associated with, "Default Gatewaty."
Here is a picture.
Afterward open your Internet Browser (Internet Explorer, Firefox, etc...) and type the IP Address associated with the default gatewayinto the address field of the browser. DO NOT add www. or .com.Afterward press ENTER or click GO as if you wanted to visit a website.
Here is a picture.
Onceyou're at the control panel you will probably be asked to log in. Ifyou do not know your login details you can always try the default. Tofind these you can either search your router's user manual or head tothe online search engines entering your router's manufacturer's name,the router's model #, and the words, "default password" into the samesearch request to bring up the default login credentials. For example:
Linksys WRT54G default password
Here is a picture.
If you still can't manage to log in to your router's control panel you will have to contact the technical support department of your router's manufacturer asking them for assistance in resetting the login user ID and password of the router.
Once you manage to log in to your router's control panel, locate the area of your router dealing with the wireless settings of your router. Once you locate that region make sure the authentication type is WPA-PSK and that the encryption type is TKIP. If those options are not available, just use the WPA authentication/encryption type. Afterward locate the region that lists your router's authentication password. Once you locate it write it down or follow instruction to locate it.
Once you have your wireless password written down attempt to connect to the wireless connection using the password you just wrote down. If it works, hooray! If not, try altering the, "Wireless Mode." While, "Auto" is convenient, not all wireless adapters can work with it. Change between the modes attempting to connect to the wireless connection every time you switch it to a new mode.
If for some reason it will still not connect, consider contacting the person who made your router for assistance in connecting to the wireless connection.
Posted on Feb 04, 2009
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
Lost wi fi connection to our wireless network, tablet displays "turning off" under the wi fi settings.
I suggest to reinstall the wireless card driver first ..just in case, this will solve any driver issues and will make it functional in case the driver or the setting are corrupted..
To download the driver in case you do not have it on disk or saved somewhere ..just go to downloads ...drivers and select the model and operation system you use..
download the wifi driver it again ..and after that restart ..and try to make the connection again ...Check the wireless card in device manager to see if it shows in order ...and did not appear in yellow which indicates driver related issues..
also be sure you have network signal ..and the router is functional case other computer is working with this network ..check to see if the connection actually works ..
To redo the connection ..just open the settings for wireless...and click scan for networks ...In the list of available connections yours..and click connect ..insert password if needed.
Good luck !
Nov 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
I cant get wi fi conection the wi fi on the computer is turn on
Try turning your anti virus off. Sometimes it interferes with wireless network connections.
Jan 13, 2011 | Acer Aspire 5315 Notebook
Acer aspire one notebook wont connect to my wi fi it was fine before
Try system restore.
Go to start - All programs - Accessories - system tools - System restore.
Try to restore your system to an earlier time - time or date when your system is still able to connect to your wi-fi router.
Jun 06, 2010 | Acer Aspire One PC Notebook
First turn on your wi fi switch on laptop.
Then go to my netowkr places proeprty and make sure your wi fi network adapter driver is installed and enabled.
Then click on view available wi fi networks then check you get signal form wi fi router.Then it works.
Let me know if you need more assistanse.
Aslo you can check in router that wireles is enabled in router?
For that connect your wi fi router to computer with ethernet cable then you can access it with following link.
typoe user as "admin' and password as "admin" or blank or "password"
then check in wireless settings that it is enabled.
Sep 24, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
How do i switch on wi-fi on my acer aspire 5735 laptop ?
Check in your laptop you find wi fi switch turn it on.
then check in device manager that your wi fi driver is installed and enable.
then view for wi fi networks then you find your router if it is in range connect into it.
let me know if you need more assistanse.
Sep 19, 2009 | Acer Aspire 5735 Notebook
My wireless won't work
check on your laptop there is 1 wi fi switch. turn it on.
Also check in device manager that your wi fi drivers are installed correctly.
then go to my netwrok places and check you find wi fi network signal.
Jul 17, 2009 | Acer Aspire 5050-3242 Notebook
NETWORK IS NOT CONNECING IN wi-fi in our wireless network with WPA2 system. but its detecting the network. should i install any new software to support WPA2.
try to setup again  wireless card's driver  if it doesnt work your wireless car is break down.
have a nice day and sorry for english.
May 27, 2009 | Acer Aspire 3680 Laptop
Wi-Fi Download problems with Acer 5920
You can try reinstall the wifi driver or update to lastest edition. Check here
Sep 23, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
