Question about HP OfficeJet 4215 All-In-One InkJet Printer
Can't send faxes
I can't send faxes but can receive them. I get the error message 420. According the the HP web site the erroe 420 is: Definition A handshaking (connection) error occurred at some point in the process from the sending fax machine.
Is there a fix for this other then just keep trying.
It is happening to every number I try.
  • 1 more comment
  • theotherhalf Jan 17, 2009
    I don't know . My phone is provied by my cable company which has fiboroptic lines for everything.
    I was able to fax just fine on Dec. 20 when the line was installed. Now I can't.
    I can pring, copy, and scan anything. I can receive a fax.
    Just not send out a fax.
  • theotherhalf Jan 18, 2009
    As stated earlier in my post it worked just fine when the line was installed. It has been in the last 24 hours it quit working.
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Do you have a DIGITAL phone service such as DSL or Vonage.
    Genius:
  • 2,120 Answers
FO is DIGITAL. You fax needs an ANALOG line.
Trust me on this.
Posted on Jan 17, 2009
What is the problem and solution to error code 420 or 321
Are you able to send fax to another # ?. Error 420 & Error 321 is mainly due to transmission of signals or incompatibility issue.
Try reducing Fax speed and turn off ECM from Fax menu and check.
Regards,
Sean
May 15, 2014 | HP OfficeJet D135 All-In-One InkJet...
EROR 420
The error that you are receiving means that the machine goes to receiving mode, but receives no command from the transmitting side. The problem is not with your machine, but from the party sending you the fax.
1. Remote side mis-dial.
2. Check with the other party.
Apr 11, 2012 | Office Equipment & Supplies
We have a receiving problem with our HP Color LaserJet CM2320nf . The exact issue is that, sometimes the machine is unable to receive a fax with any number of pages from different senders Also, the...
Error Code 223 (ECM error)
The receiving product has been unable to receive an entire page even after multiple attempts to rereceive the parts of the page that contain errors. This is usually due to extremely poor line conditions.
1. Reattempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, disable ECM. Errors may still occur, and may result in degraded image quality on the received page. However, the ability to receive the entire document will be improved.
Error Code 420
V.34 negotiations have failed from the originating product during phase four, which occurs after V.8 and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Reattempt the fax transmission at a different time when telephone line conditions have improved.
Error Code 421
V.34 negotiations have failed from the originating product during phase three, which occurs after V.8, before phase four, and before the first T.30 frames are exchanged. Compatibility problems have been observed in this area when sending to non-HP units.
Jul 20, 2011 | HP Laserjet CM2320nf All-In-One Color...
Problem faxing-error message
Error 388:
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 7140xi scanner failure error
Please click on the web link given below and perform the steps as given in the web page to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00787271&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
For further information contact HP chat support, its free of cost.
CLick on the web link to chat with HP technician.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
Oct 13, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
177 people viewed this question
Ben Johnson
