Question about Dyson Vacuums
Not picking up and the brush does not move
Very little suction and the brush isn't turning
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 62 Answers
Check to make sure that the knob for carpet/ bare floor has not slipped, the brushroll will only turn when carpet is selected. The most likely culprit is a stretched belt on your clutch assembly; you have one tor the brushroll and one to the motor. These belts will stretch out though Dyson will not tell you this. Best remedy is to replace the clutch assembly with OEM # 900252-04. Dyson will sell the Brusholl belt but I suggest shopping arround to find someone willing to pull the clutch apart; to my knowlege Dyson will NOT sell the motor belt.
Posted on Jan 17, 2009
SOURCE: my hoover upright has no suction, the brushes move
Hi there...
I had the same problem. Checked for obstructions, cleaned the filters, etc.
 I took out the rubber belt and noticed that it was much more stretched than the newer black belt.   I replaced it, and it made a 100 percent improvement on the suction.
Your vaccuum should have come with a postcard that allows you to mail in belts for new ones. You'll get two new ones in the mail, and they are free for life.  Just keep mailing in the old broken or stretched out ones.
Hope that works!
Posted on Apr 08, 2009
juststinks
  • 98 Answers
SOURCE: Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
Posted on May 08, 2009
SOURCE: Have suction, new bag, brush moving but does not
Solved!!!
I went to my local Sears store and the salesman there looked at my vacuum and was able to resolve the issue. There was a piece of wire that had been sucked into the machine that then blocked anything else from being vacuumed up.
Thanks for your help.
Posted on Jun 19, 2009
  • 15 Answers
SOURCE: My vacuum isn't cleaning/suctioning very
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Posted on Jul 09, 2011
  • 910 Answers
SOURCE: Dyson DC07 roller brush not
Video below shows how to access the drive belt to check/replace it.
If you require any further assistance then please just let me know.
Posted on Aug 09, 2011
Hoover u6485-900 Brush Bar won't turn.
Hello. Make sure that the brush bar is clean and that there is no hair or strings tied up.
Apr 18, 2014 | Hoover U6485900 Bagged Upright Vacuum
Hi I have a dirt devil vision. Hose works, but does not vacuuming the floor. Belts are not broken. Larger belt is moving, smaller belt that moves the brushes does not.
hi krueger, sorry for the problems but hers an idea how about turning on the vacuum and put your hand under the part where it sucks uo the dirt off the floor and i guessing you would have a little suction, since the brushes are not moving its going to not pick up as well as it should my guess is that the belts need to be replaced even if one is moving, i would change both belt to be sure and also are you smelling a burning smell if so then that would prove fact to needing new belts, hope this helps, Jamie
Dec 14, 2012 | Dirt Devil M086700 Vision Bagless Upright...
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
Why does my vacuum leave a trail of hair on my floors when it's being pulled backward but suction up fine when it's going forward?
It is because the belt is worn and stretched. when you go forward there isn' t as much resistance and the brush can turn and pick up, but when you go back there is more resistance and doesn't pick up. You simply need to replace the belt. Here is the belt you need:
Eureka Boss 5849 Belts
May 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
The spinning brush isn't moving
Belt may be off the motor spindle, with the vacuum off try turning the brush by hand, does it turn freely or can you feel the resistance of the motor?
May 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush doesn't spin and there is no suction there either, the brushes move freely when manipulated manually
Check for clog in the hose or what ever connects the nozzel to the collection device. I pick up vaccum cleaners all summer, most new, all clogged, all from the trash.
If possible, take the machine outside, open the collection device, run the motor. Is there suction you can detect anywhere?
Sep 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
Vacuum will not pick up, the dirt just lays inthe bottom of the hose and does not get sucked up,i looked for aclog but there isn,t one
Are the filters clean? Is the brush roll turning? Otherwise check the dirt inlet by the brush roll for a clog. Pull the hose off from the bottom, is there suction there? If there is, then the problem is below where the hose is pullged into. If no suction, then there is a clog in the hose, take it off, (if it comes off completely), drop something like a heavy marble down the hose and see if it comes out or not.
Jun 16, 2008 | Dirt Devil Vacuums
No suction when carpet cleaning. Also won't stand upright
Its possible that it may be blocked in the foot of the vaccum. try going through your instruction manual to locate details on how to disassemble the suction brush and connecting ducts. If you dont have one then use this link to download it. http://ubermanuals.com/node/1870
Let me know how you got on
Cheers
Jun 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
136 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
