Insignia ns-lcd32 lcd tv not working
Hello, the tv will not power up for no apparent reason. No menu, no sound, no backlight. Worked fine the night before. The little green light on front panel flashes but that is it.
1) Unplugged unit for 2 hours. Nothing
2) Took back of tv and inspected power supply, Nothing smells burnt. Looks ok but that probably doesn't mean much.
3) Found power supply boards on ebay but I dont want to spend $50.00+ unless I am sure it the problem.
Any ideas would be appreciated. Thanks Rob
  • 362 Answers
Yes agreed, it is the power supply. Here is a link to buy it, I buy many parts from here and have only had to return 1,
http://www.shopjimmy.com/showparts.cfm?item=802301&ps=8023&pn=1
Be careful buying parts from Ebay.
Lone99star
Posted on Jan 26, 2009
    President:
  • 2,110 Answers
It is definitely the power supply board..
Posted on Jan 17, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! This is your Power Supply causing this Problem. Sounds like you can change this out yourself. You just need to Locate a Power Supply.
  • 837 Answers
What is the flashing sequence or is it constant?
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
How can I reset my insignia tv #NS-LCD32 to global volume unlock with a RCA universal remote
Try this solution by another user:
timyorba 1 solutions Jul 21, 2011
So, For anybody who doesn't know yet, you do not need the factory remote to restore button functions to your Insignia IS-LCDTV26. All you need to do is program a universal remote that can power on and off the TV, then
"**press the "MUTE" Button 10 times successively**"
and Voila! Unlocked, you should see the status appear in the corner of the TV if everything worked, if not try another tv code or try the manual search function on the remote to find another compatible code set.
Dec 26, 2012 | Insignia NS-LCD32 LCD TV
No sound
Check the usual things:
In menu speakers not switched off.
Set not set to external speakers if equipped.
Does the set have sound when a DVD connected to a rear input is used?
Oct 29, 2012 | Insignia NS-LCD32 LCD TV
Insignia ns-lcd32 has developed a vertical shadow.
Unfortuntly you have a panel that is going out. This is not cost effective to fix.
Apr 11, 2012 | Insignia NS-LCD32 LCD TV
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).
In either case not cheap.
Mar 23, 2012 | Insignia NS-LCD32 LCD TV
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
Dec 30, 2008 | Insignia IS-LCDTV32 32 in. Television
I have the following tv, Insignia 32" Flat-Panel LCD HDTV** (NS-LCD32-09CA) I get audio sound but no video output
Power supply board most likely, I have one just like it with the same problem in my shop right now.
Dec 26, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
Top Televison & Video Experts
