Question about Honda Pressure Washer PSI 3000
How to remove carbeurator on honda gx 390
I am not sure how to remove carb. there are two threaded bolts that also secure the air filter housing but once the nuts are removed i don't see any obvious place to remove the bolts and carb.
  • 31 Answers
Remove the wing nut on top of the air filter housing. remove housing. remove next wing nut over air filter. remove air filter and bottom of housing. next, remove the 2 nuts on those threaded bolts you saw. there is one more bolt that you must remove located between the air filter and the exhaust. now the carb can be removed. this is possibly going to be very difficult but trust me, it can, and must be done. the carb should slide off of those bolts once you break it free from the intake. get your pry bars ready but try not to break any of those plastic parts! good luck.
Posted on Apr 01, 2009
Did not need to remove carb. just removed the bowl and did a real good cleaning on the float valve, used a cleaning solution. The leaking gas was a stuck float not a bad gasket. Thanks
Posted on Jan 18, 2009
Ihave a honda generator with a gx 390 motor volt drops when i put a load on it what could it be
Voltage regulator, carbon buildup in the cylinders, the carburetor may need overhauling, engine governor may have a stretched spring, Spark plug may need replacing, Timing may be off, air filter may need changing, and lastly, your load may exceed the ability of the generator.Checking this list will uncover the loss of power
Oct 20, 2016 | Honda Electrical Supplies
Removing carborator
To remove the carb, first undo the 2 bolts on the front of the panel to expose the air filter area. Then undo the 2 nuts either side of the carb air hole. This will help you remove the rest of the control panel, reveiling the carb.
Have a portable generator question? We are always happy to help. Generatorguru.com
Generator Guru
Aug 01, 2014 | Eastern Tools And Equipment 1200 Watt...
I have an older model Powermate 8125 watt generator with a Honda GX 390 engine. The unit has been setting up for 4 years so I disassembled the carburetor and soaked it in carb acid. The main jet was c
Clean all the ports and jets with some torch tip cleaners or mechanics wire cut at an angle to be sharp.
Make sur ethe fuel filter is not clogged, or the sreen in the tank.
Also empty the tank and dry it out, then add fresh fuel as gasoline goes bad.
Apr 18, 2013 | Horizontal OHV Engine 390cc, GX Series,...
Press. Washer Honda engine gx 390 will not start
did you leave fuel in it from last year, if so remove all fuel from tank, drain carb. (remove float bowl if it doesn't have a drain bolt) put in fresh fuel, check your oil level and you should be good to go. if not, please take it to a qualified tech. for carb. cleaning.
Doc
May 17, 2010 | Karcher G3025OH Pressure Washer
2000 harley davidson softail standard,pops,and sputters on acceleration,and also when idling when you rev it up it takes a while for it to come back down to idling. it started shortly after i changed the...
I'd be willing to bet that you removed the carb to replace the choke cable as it's very difficult to replace with the carb in place. Now, did you replace the seal that the carb "plugs" into? I've seen this happen many times. I never take a carb off an Evo or later model engine with the spigot mount carb without replacing that seal.
The only thing that you didn't mention was the response of the slide in the carb. With the air filter off but the backing plate still on the carb, rev the engine and make sure the slide is going up and down. If not, you've probably got a hole in the diaghragm.
More than likely, you've got a vacuum leak at that carb seal. When you put the air filter backing plate back on the engine, you should not have to move the carb up, down, or sideways to get the three screws started in it. If you do, you need to replace the seals on the manifold at the heads and realign the intake.
If you determine that you need to do this, replace the intake seals at the head but leave the manifold bolts loose. Replace the carb into the manifold, and install the air filter backing plate. Once it's all installed and aligned correctly, tighten the two bolts on each runner of the intake at the heads.
I hope this helps, Good Luck
Mar 03, 2010 | 2000 Harley Davidson FXST Softail Standard
I have a Honda GX 390 with 13 hp power washer. Overheating.
Make sure the engine is not full of paint or dust debris in it's cooling system. If the fuel mixture setting is very lean, it can cause overheating. Make sure the fuel tank vent is open to prevent fuel starvation. Does the engine seem to be running at full operational speed? If not, it will be short on developed horsepower. Make sure the water source is not partially shut off. Hope some of this helps!
Feb 25, 2010 | Air Tools & Compressors
How to replace engine air filter in 2001 honda odyssey
The air cleaner element is inside the air cleaner housing on the driver's side of the engine compartment.
To replace it:
1. Remove the two pins holding the air intake cover by pulling the head on each pin. Remove the air intake cover.
2. Loosen the four bolts by using a Phillips-head screwdriver.
3. Disconnect the clip from the bolt on the air cleaner housing, then remove the air cleaner housing cover.
4. Remove the old air cleaner element.
5. Carefully clean the inside of the air cleaner housing with a damp rag
(The coolant lines inside the air cleaner housing may be warm. Do not open the hot air valve when cleaning the inside of the air cleaner housing)
6. Place the new air cleaner element in the air cleaner housing.
7. Reinstall the air cleaner housing cover. Reinstall the clip on the bolt; make sure the clip is under the washer. Tighten the four bolts.
8. Reinstall the air intake cover. Reinstall the two pins and secure them by pushing on the heads until they lock.
Hope this helps you through the process.
Nov 23, 2009 | 2001 Honda Odyssey
Echo blower wont start after replacing air filter kit
MAKE SURE THE CARB BASE GASKET IS IN PLACE AND IN GOOD SHAPE
Sep 24, 2009 | Echo Pb - 413t Backpack Blower
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Honda gx 390 only starts when it feels like it
Sometimes you have to lower the air pressure in the tank to allow it to run. The back pressure from the compressed air in the compressor head overcomes the pressure created in the engine at the slow RPMs you are able to pull while attempting to crank it.
Aug 13, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Honda Pressure Washer PSI 3000 Logo
220 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
