Question about InFocus ScreenPlay 61" Rear Projection HDTV
Infocus 60md10 not turning on
Remote stopped working so tried to unplug and reconnect power supply. When reconnected, front blue display lights stay lit (not blinking) but nothing happens. Remote and front buttons do not respond. Can you help?
  • 2 more comments
  • elagartijo2 Feb 07, 2009
  • hardRESET Mar 06, 2009
    I have the same issue after a power outage. When I reconnect the power the front blue display lights stay lit (not blinking) but nothing happens. Remote and front buttons do not respond.
  • drewsheldon Apr 19, 2009
    I have the same problem with my set. Has anyone found a solution or more information on this issue?
    Thanks
  • Voodoo00 Apr 27, 2009
    I have the same problem. Any solution?
Mine was doing this for a while and now is completely black all the time. I have a thought as to what this might be... I believe the problem is not the lamp or light engine but rather one of the brushless fans failing. This causes the tv to shut down as a safety measure because of the inability to purge the heat that would build up VERY QUICKLY and warp, damage and destroy everything else. I believe the problem being intermittent at first is due to the fan performing a "death rattle". The fan itself could be fine and more of an indirect problem. I believe the wiring coming out of the fan is inadequately insulated against the heat generated. It begins to cook, crack and eventually fail.
The good news? If it is the fan they cost about $15 and can be purchased on the internet. Nothing special about them. You would want to make sure it has the same leads coming out of the fan to facilitate the changeout. Again, I haven't attempted to install a new fan on mine yet but it will be the first thing I try.
If any of you attempt this before I do, please post your resulting experience for the rest of us. I will do the same. Good luck.
Posted on May 04, 2009
Dell dimension e510 flashing amber light USB front panel
If you are comfortable around computers, you could try the following to test the power supply. Unplug the cord from the power supply, hold the power button in for about 15/20 seconds, open the case, unplug the 24-pin power connector from the motherboard and jump the Green wire to one of the Black wires, reconnect the power cord and power the system on and if power supply fan and hard drive run, then the PSU should be good. Note: Do not remove any wires from the plug, use a small piece of wire or a paper clip as a jumper. Power supply checks out and the system still does not work, again remove the power cord, hold power button in for several seconds to discharge the residue power, reconnect the 24-pin connector to the motherboard. Remove all the PCI cards, the video card [if applicable], memory, all peripherals, disconnect the data and power cables to all the drives, check that the front panel cable is connected to motherboard, with nothing else connected to the system, reconnect the power cable and power the system on. If you do not get any beep codes or diagnostic lights on the front panel, then it would appear that motherboard has died.
Aug 07, 2012 | Computers & Internet
P4m800pro-m v 2.0 no display troubleshooting
Power off, remove AGP (video) card, unplug hard drives, cdrom, and remove all PCI cards. Unplug everything but keyboard and power. Power on and boot.
How many beeps do you hear (one is normal)?
If none, are fans spinning?-> Is the front power light on?->
If no, then try different power supply, if that doesn't get beeps, then motherboard is probably bad.
If you DO hear beeps, make a note of how many, then power off and replace AGP card. Power on. Do you have display, or do you hear beeps? If you have display, power off, reconnect hard drive(s), power on. Still working? Then power off, replace cd-rom, and power on. Still working? Power off, replace PCI cards, and power on. Still working? Then you fixed it. ;>
if it stops working after reconnecting or reinserting something, that something is probably bad. Leave that thing out, and keep going.
Sep 08, 2010 | EliteGroup Computers & Internet
Hey Axle, I have run into an issue that has stumped me. I have a 50" Vizio Plasma made in 2006 the model is P50HDTV10A. I am confident that how the problem occurred is lighting ran in on the TV. What...
TRY TO UNPLUG THE POWER CABLE GINIG TO THE Y BOARD THE ONE COMING FROM THE POWER SUPPLY SOMTIMES BLUE AND WHITE IF CLICKING STOPS Y IS SHORT IF NOT UNPLUG POWER CABLE FROM POWER SUPPLY TO X BOARD CLIKING SHOULD STOP IS YES ITS THE X BOARD THATS SHORT TAKE TIME TO UNPLUG YOUR TV BEFORE DISCONNECTING ALSO BEFORE RECONNECTING Y AND X WAITE ATLEASE 5 MIN FOR CAP TO DISCHARGE
Jun 08, 2010 | Televison & Video
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Infocus 61md10 wont boot up
Unplug it from power source for an hour to two hours reconnect and turn on
Aug 16, 2009 | InFocus ScreenPlay 61" Rear Projection...
2nd wii remote will not connect with mario play 8
We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
This is from www.nintendo.com/wii :
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Dec 23, 2007 | Nintendo Wii Console
Problem
Going back some time ago, I believe that in this model of set, if there is a power supply failure, the sleep timer will show as activated.
I suggest calling the JVC service rep to find out details for this. I believe the power supply will have to be changed. Also, the tech will check the set to find the cause and service it as necessary.
Jerry G.
Oct 31, 2007 | JVC AV-27D302 27" TV
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
InFocus ScreenPlay 61" Rear Projection HDTV Logo
281 people viewed this question
Top InFocus Televison & Video Experts
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
