Question about Yamaha HTR-5990 Receiver
Yamaha HTR-5990 Audio no longer works
My Yamaha HTR-5990 reciever has a 5.1 sourround sound setup configuration. My wife phoned me yesterday from home to let me know that "it just stopped working". I recieve video from all components but do not hear any sound what so ever. The reciever turns on, I hear the standard "click" noise that it makes but I can't get any sound. I've tried to run the YPAO setup multiple times but it keeps failing with an "Internal 10 Error: Rerun setup". I actually had this happen to me when I moved into our new house multiple times but after about 20 attempts it finally worked. My HDTV is configured via HDMI to the Cable/Sat Tv input My Xbox is used as our DVD player and is on the DVD input and uses component video and optical outputs for sound. HELP! PLEASE! Michael
    President:
  • 3,130 Answers
Sorry Michael, you have a problem in the audio amp section of the receiver and unless you know how to troubleshoot solid state electronics, you will need to have this unit serviced by a pro. Good Luck
Posted on Jun 25, 2007
2 Suggested Answers
  • 12 Answers
SOURCE: Yamaha HTR-5990 Audio no longer works
Hi everyone:
You may reset your unit, to do so here is the procedure.
1. Depress the MASTER little Button so it has to be in the OFF position
2. press simuntaneously the A/B/C/D/E and TUNNING/CH > buttons and the press MASTER again
3. Keep the two buttons pressed until the SLEEP blinks on th display, at this point you will see a message that last for maybe 3 seconds,
4. after the message you will see the number 1 and a series of numbers on the first row and the word MARGIN on the second row.
5. Turn the PROGRAM knob until you reach tothe number 11 FAC PRESET on the first row and PRESET INH on the second row
6. press the TUNNING/CH > button once, and the message on the second row will display PRESET RSRV
7. Press the MASTER again and your unit will have the factory settings.
I Hope this solve your problem
Miguel
Posted on Feb 16, 2008
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
Yamaha HTR-5990 Receiver the HDMI inputs only one works is the other switchable?
according to yamaha website you have 2 hdmi inputs, and one hdmi out on that unit
Mar 07, 2013 | Yamaha HTR-5990 Receiver
No compressed audio on hdmi If I send compressed Dolby Digital to the HTR-5990 via HDMI, the indicator shows "PCM" and no audio is heard.
You probably need to take that issue up with the setup of the unnamed device originating the signal.
Mar 23, 2010 | Yamaha HTR-5990 Receiver
What model of remote comes with this yamaha htr 5990
The RVA350 comes with this model according to the manual.
Hope this helps
Oct 07, 2009 | Yamaha HTR-5990 Receiver
I have YPAO showing on my display and I can't get a picture on my tv. Do you know what YPAO means?
The receiver is in "Setup" mode and wants the microphone plugged in for testing sound parameters. Press "menu" on the remote, this will exit the mode. If you still have an issue, post a comment and I can help you some more.
Aug 04, 2009 | Yamaha HTR-5990 Receiver
Yamaha sourround sound reciever HTR 5920- not working
Can you remove connection between the receiver and TV and then try ? If it still turns hums and turns off, then try disconnecting all the speakers and power it on. If it still turns off, then you have a bad receiver...Let me know..
Mar 20, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Yamaha HTR_5990
unplug everything that is pluged into the reciever. plug the power cord into an outlet with nothing else pluged into it and try it again. if your electronically experienced you could try to ground it and carefully try it again. give the unit a smell, does it smell a little burnt? if you have a screw driver and a little trust in yourself tale the cover off and look at the board for visual burn marks there should be fuses inside the unit, you could check those out. If you dont see anything visually wrong and it is still not powering it would be a good idea to bring it in to an electronics repair shop and they could diagnose the problem. With the use of a volt ohm meter it would not take long.
Jul 28, 2008 | Yamaha HTR-5990 Receiver
No sound from Yamaha HTR-5990
You must be sure that you also have "audio" cables connected to the receiver to make this all work. As far as the TV is concerned, the same applies....accordianman
Oct 31, 2007 | Yamaha HTR-5990 Receiver
MichaelM
Did you ever get this resolved?  I have a similar problem, my video feed seems to work but I have never been able to get any sound from my speakers using this component.  I'm not sure what YPAO setup is but I just read a suggestion to reset the receiver to factory settings in the event something is programmed that causes the problem.
Jun 21, 2007 | Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
May 01, 2007 | Yamaha HTR-5990 Receiver
Yamaha HTR-5990 Receiver Logo
301 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
