Question about Jenn-Air JGR8775QD Gas Kitchen Range
Oven slow to heat up
The JennAir gas stove takes a long time to heat up in either convet or normal bake mode. What normally would take a few minutes to reach 300 degrees now takes 30 minutes and sometimes does reach the set temperature. There seems to be enough gas presure to work the gas top range and other gas appliences in the house. Any suggestions.
Thanks
  • 833 Answers
SOURCE: Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Posted on Dec 13, 2007
  • 114 Answers
SOURCE: Possible Control board problem
You may not necessarily need a new control panel. Sometimes the oven temperature can be calibrated. Look in your owner's manual (if you have one) for calibration instructions. This will usually take care of the problem. If not, you may have to replace the oven sensor located inside the oven in the upper right or left hand corner of the back wall. Good luck.
Posted on Feb 08, 2008
MNTECH
  • 1543 Answers
SOURCE: Re: GE Electric Range JBP67BD1WH Baking Element Problem
Before you replace the range, I'd try replacing the oven temp sensor (part number WB21T10007 ) which is rather inexpensive. If I were able to get my hands on your range I'd first test to see if the control is sending 240 volts to the bake element. We know there is 240 to the range because the burners and broiler work, but is the control sending the full 240 to the bake element ? The only way for you to know this is to use a meter and test the voltage across the terminals of the bake element when in bake. Of course you should also test the bake element with power off and at least one terminal disconnected to see if you have about 20 ohms resistance across the terminals and no resistance from a terminal to the frame of the range. If not, you may need a new bake element (part number
WB44T10010 )
Let me know if I can be of further assistance. Thanks for using fixya.
If this helps, a fixya rating would be appreciated. Thanks.
Posted on Nov 08, 2008
RescueTech
  • 145 Answers
SOURCE: oven slow to heat
An extremely common problem on these models is a weak silicon carbide ignitor. You may be able to see the ignitor glowing, but that is not an indicator of it being functional or not. When the ignitor gets "weak" over time, it will not create enough amperage in the circuit for the gas valve to open. You can test this using an amprobe around one of the ignitor leads and looking for at least 2.9 amps, but years of working on these appliances has shown that if you are getting the glow from the ignition but the oven is often slow to come on, you need a new ignitor. Do-it-yourselfers often mistakenly replace the oven valve or the oven temp sensor, figuring the ignitor must be good because they can see it glowing.
Replace the ignitor and your oven will work great again.
Posted on Dec 14, 2008
fixyourboard
  • 310 Answers
SOURCE: Amana Range, AER5515QAW
could be a bad bake element, bad temperature sensor, or control board problem
what does the oven readout display for temperature? if the readout agrees with the actual oven temperature ... it is probably the element
if the oven readout displays a much higher temperature it may be the temperature sensor (the probe in the oven cavity) or the control board
the temperature sensor can be tested by measuring its resistance with power off and unplugged from the control board, should be about 1100 ohms at 75F
If the sensor is good, then it is probably the control board ... in which case we can repair it for you at www.fixyourboard.com
Posted on Jul 21, 2009
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirpool gas range - propane gas not sure oven is working right
First, the flame should be blue and without much visible yellow. You need to give the gas tube a good cleaning to get out any soot buildup and any partial obstuctions that might be causing the problem. Since you started with a yellow flame and soot, you need to get the burner tubes clean to see if you have resolved the problem after adjusting the regulator and burner valve(s).
You might need to install a different regulator to match the pressure of your gas supply source, as regulators have a specific working range of inlet (supply gas pressure) that they can operate properly at to "regulate" the supply pressure to the stove's needed pressure.
Check your manual and the installation guide to verify what the gas inlet pressure requirements are and check with your gas supplier to see what they are providing you.
To your 2nd question, yes, the gas will cycle on and off when you are using the oven, since the thermostat will call for more heat when needed and shut off the gas/flame once the temperature you set the control at, has been reached. The cycling is a result of the oven trying to maintain the desired temperature for baking.
One reason that you can smell gas when the oven is being used, is because all gas ovens have a surface vent to allow excess heat to escape from the oven compartment, however you should not be smelling raw gas (actually you're smelling the "rotten egg" additive that's put in the gas) all the time, since when the oven is turned on, a small electric ignitor is heated up VERY HOT glowing bright orange inside the oven compartment. Once it's hot enough a sensor opens the gas valve and lets gas into the burner tube to be ignited instantly by the VERY HOT ignitor. It is rare to smell raw gas with this system, but sometimes you'll get a stronger "rotten egg" smell at different times due to the gas company and their system, etc.
As to the gas smell, you should NOT be smelling gas every time the oven cycles on when baking, as a normal ongoing occurrence. During the first few uses, it is normal to smell some gas, but this should go away after a couple of uses. If it doesn't, you should look to make sure the regulator and oven controls are PROPERLY configured and set - Since you've already fiddled with these, it's probably a good idea to have someone from your gas company (or a gas appliance tech) come out and do this. Improper settings can cause some serious problems.
Hope this helps!
Jul 15, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Oven will not heat
ok few things sound like the gas valve may be turned off what i mean about turned off is at the gas valve contro;l normally installed under the stove on the left side of the valve tere is a verry small lever that serve as a shut of vave i have seen those lever in plastic normally red it may have sticked it self close or fallen out check on the floor if you do not see any small parts another thing check for fuse also there is a solenoid valvve that possibly not opening up one more thing does your stove connect to a normall 120 volt plug or does is connect to your 220 volt electric stove plug with a adapter if so check your breakers thanks gilles_dumais@hotmail.com
Mar 15, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
GE gas stove
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
Oct 06, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Normally hw many minutes it takes to heat water or food
I can't view all of your question, so I will answer this to the best of my ability. If you're talking about heating a cup of water, it normally takes 1 minute or less for the standard microwave oven on HIGH. About 2 minutes if you want boiling water. I hope this is what you were asking. If not, provide me with another question and I'll see if I can give you a better answer.
Jul 12, 2007 | Electrolux EMS2487X Convection Microwave...
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Jenn-Air JGR8775QD Gas Kitchen Range Logo
131 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
