Question about Kenmore 63942 Dryer
Kenmoore Dryer will not start
I have a Kenmoore Dryer Series 80. It will not start, I have power to the start switch. When I press and hold the switch you can hear a timer running, but stops when released.
  • 6 more comments
  • randy_shrade Jan 18, 2009
    Not Just the timer running,
    The Model number is 110 668 12694. Thank you for looking into this.
  • Anonymous Jan 18, 2009
    how do i change the door switch on my kenmore dryer
    Not really. I do know that when you toggle the door switch it will turn the light inside off/on thats about all I can tell you.
    Okay I have checked that when the door is open and I press the start switch nothing happens. When I close the door and press the start switch the you can hear the timer running. I have started to remove the panels to gain access to the door switch.
    Okay. I have removed the switch and checked continuity. 1 to 2 I got 0.1 ohms 1 to 3 I got 0.2 ohms when I toggled the switch
  • randy_shrade Jan 21, 2009
    Hey Onthejob5130 Thanks for your help you guided me in the direction I needed to go. I found a schematic inside the dryer and traced from the door switch to the dryer motor and found that the thermal switch was blown. Thanks again and keep up the good work...
  • onthethejob1
    onthethejob1 May 11, 2010
    do you here the motor humming
  • 640 Answers
Ok im with you,,send me the model #..and check your door switch..i want to veiw schematic on this,,,we have a defective part..
Posted on Jan 18, 2009
  • 3 more comments
  • onthethejob1
    onthethejob1 Jan 18, 2009
    are you sure the dood switch is good
  • onthethejob1
    ok randy ..in you case i need to kow if that door switch is good ..if not replace timer...to the guess that want to know how to change door switch,,im assuming you have same model as randy...pull your filter oue on top of dryer,,now you see the 2 phillips head screws remove them...now get your putty knife,,always unplug first,,push your putty knife in between the front right corner of the top and the front panel 1 inch away from the corner,,you will fill a clip now push in with your putty knife..and pick up hold top..now do the left side....look straight down on the right hand side front..you see the switch,,disconnect now to remove open door than remove 2 screws on the underside of front panel,,reverse to put together....,,note to randy you need to test this switch,,switch part #3406107,,onthejob
  • onthethejob1
    good alwats unplup...1 wire is hot,,and 2 on the same side of the swich 1 goes to lite,,and the other goes to the motor,,we want to check that 1,,for continuity
  • onthethejob1
    okm you marked your wires and disconnected them,,now im not sure how you got any resisitance through a switch,,,you should of got ,,not wire was 000..ok put the lead on the with 1connetor..not pushed thats the lite...0000..now push that the motor,,,ooo..rite
  • onthethejob1
    onthethejob1 Jan 23, 2009
    sorry randy ,,i do work for and appliance company,,and boy they sure are calling in,,everyone whants to fix,,..anyway glad you got the job done,,,onthejob
Does a kenmoore 80 series have glides
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-PYE2300AYW/3048/0151200?pathTaken=&prst=0&shdMod=PYE2300AYW
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
Where's the fuse of the kenmoore dryer 80 series?
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 01, 2010 | Kenmore Dryers
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Kenmore 80 series Dryer: Door Light stays on and wont start
Mar 05, 2009 | Kenmore 800 7982 Dryer
80 Series Kenmoore will not spin or timer move
the timmer were the knob is attached to has gon bad it very easy to replace 8 screws and one plug part can cost from 40-80 dolllars
Dec 19, 2007 | Maytag PAV2300 Top Load Washer
Kenmore 63942 Dryer Logo
251 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
