Question about Black Box (IC109A-R3) Transceiver
Does not transmit
No transmit light activity. Power is on, recieve light is on.
    Scholar:
  • 66 Answers
Model #? Name?
black box? make sure the tx rx are reverced on both ends.
Posted on Dec 28, 2007
SOURCE:
My cobra 25 transmits but doesnt recieve. I changed all finals but it still will not recieve. Any ideas on what i need to do
finals have nothing to do with rcv.
u need to trouble shoot the receiver.
start at the t/r switch and make sure the antenna is connected to the front end of the rcvr when xmit is not active.
if u hear absolutely nothing u may have an audio issue. try a headset and work backwards.
Dec 25, 2014 | Radio Communications
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
Realistic trc 443 cb quits transmitting and recieving
Sounds like the weather alert system is getting activated.
Jul 26, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
3 light on last two blink
The first light, I assume is on constantly, is power/connection, and the two that blink will be Rx and Tx, Rx = recieving data sream, Tx = sending data stream, even if you think that nothing is being transmitted, "static" is sent/recieved to maintain your connection.
Jun 11, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Recieve and Send lights blinking
Are you unable to connect? The send and rcv lights should be blinking. Make sure that your link light is on and not blinking. Your link light is your connection to your ISP
Feb 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Neither Radio Transmits or Recieves
Have you checked that both radios are in the same Channel and the same Squelch Code? are the batteries ok? any rust in the battery contacts? Some FRS radios gets a Malfuntion, and the syntom is like that, check this first
Nov 26, 2006 | BellSouth 2231TE (22 Channels) 2-Way Radio
Open Questions:
See all Black Box (IC109A-R3) Transceiver Questions
Black Box (IC109A-R3) Transceiver Logo
160 people viewed this question
Top Black Box Computers & Internet Experts
Ekse
Alun Cox
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
