Question about HP PSC 2175 All-In-One InkJet Printer
Right cartridge incorrect message
After successfully copying one page, I received an error message:
"right cartridge incorrect".
    President:
  • 2,692 Answers
Posted on Jan 18, 2009
Cartridge error HP2210
Buy a new one. It is the correct cartridge, but it might be "broken". That happens all the time- one of the wires on the cartridge electronic has blown and the printer now does not see the cartridge, that's why you are receiving that message.
Feb 17, 2010 | HP PSC 2210 All-In-One InkJet Printer
My lexmark 7170 printer has error message : right cartridge incorrect. I pulled the brick. Waited a few minutes, replaced but error still appears. Turned off and on etc. Lexmark quide was not helpful. any...
You are trying to put the wrong catridge into right hand side,. the catridge you have put is incorrect. try removing the catridge and put the right catridge back
Jan 09, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Incorrect Cartridge Print cartridge in right stall not supported?
I changed the cartridge and it now works. I resent this though because it had been merrily printing before it decided it would stop and I have had to waste a three quarters full cartridge! I just hope the new one does not go the same way
Apr 08, 2009 | HP PhotoSmart C4180 All-in-One Color...
Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
Here's the relevant link:
Cleaning the Print Cartridge
Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Incorrect right cartridge
Ive tried removing the right cartridge so I can print in black, but now , once I refilled the black one, it wont even let me print black!! this is desperate; can anyone help?
Aug 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Cartridge problem
removed both cartridges and reinstall again, pls make sure that the cartridges are seated correctly
Jul 15, 2008 | Dell 924 All-in-One InkJet Printer
Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark x5470
A Right Cartridge Incorrect message generally indicates a communication error between the All-In-One and the cartridge. This can be caused by a faulty cartridge; however, it may be due to a simple interruption in the communication between the cartridge and the All-In-One.
The procedures below will help you to identify the cause of the error and resolve the issue.
Rebricking the All-In-One and Resetting the NVRAM
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action 1 Power off the All-In-One and remove the power brick from the back of the unit. Wait 20 seconds. Then reinsert the brick and power the unit back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Reset the NVRAM of the All-In-One
Yes: Continue to Checking the Cartridges.
Step Action 1 Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3 Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4.
4 Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts (click here for instructions). Continue to step 5.
5 Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6.
6 Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Nov 11, 2007 | Lexmark X5470 All-In-One InkJet Printer
This solution (RESET the BRICK - solution 1 above) worked for me!
I had a brand new out of the box Lexmark X4580 and after one or two prints I was suddenly getting a "Left Cartridge Incorrect" error showing on the Printer Control Panel and the printer would now all me to print anything.
After about an hour of trying this and that (cartridges in, out and shalen all about!) ; no avail, I tried this and hey presto, it worked.
When I removed the "Brick" power supply I left it until the Green LED had faded right out though, I dont know if that was significant or not. Fingers crossed all is sorted now!
Mar 14, 2007 | Lexmark X7170 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
473 people viewed this question
Ben Johnson
