Question about EXPOBAR Office Control Espresso Machine
The machine doen't turn on.
When I flip the on switch the red light comes on it makes a click sound but then clicks again after 2 sec and the control panel lights, showing the cups turn off. The on light stays on.
Thanks
Ben Barrera
  • ben373 Jan 18, 2009
    My Expobar expresso machine - when I turn on the switch it doesn't turn on. The panel light blink on and off. The switch makes a clicking noise initially when I turn it on and another clicking noise in about 2 seconds.The "on" red light stays on, but no panel lights.
    Master:
  • 416 Answers
There are two problems that are nearly impossible to fix: failure of one of the heat-sensitive switches and failure of the heating coil. Because it's very challenging to get replacement parts, you'll probably have to buy a new coffee maker if one of these problems disables your machine.
The power cord or on/off switch can go bad. In either of these cases, it's best to get a pro to replace it or buy a new coffee maker
The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick. If you use house water softener it might over saturate the coffee and causes problems with the machine.
The tubes can get clogged with calcium.For the same reason tap water can cause deposition inside the machine This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
Good Luck
Posted on Jan 18, 2009
  • 153 Answers
The lights r on because of short circuiting inside check wit the wiring in the machine that might hepl
    Sergeant:
  • 221 Answers
You'll need to do continuity checks on the pstat contacts (probably OK given the heating light), the heating element itself, and check if there's an SSR on the circuit. If there is, it shouldn't be dropping more than 1 or 2 volts across the power side when its on; if it's reading a full 110, or a large voltage, it's dead
Posted on Jan 17, 2009
  • 837 Answers
Try unplugging it from it power source for at least 10 minutes and try again
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
IA THIS RVICE FREE I HAVE BEEN UNEMPLOYD FOR 2 YEARS AND IHAVE RIEND THAT I THNK AN D TEWORK IF I CAN DETERMINE THE PROBLEM
Sounds like the power supply capacitors have failed. If you can't replace capacitors on a circuit board on your own, it's time to take in to a repair shop.
Dec 08, 2014 | Samsung HL56A650 56 in. TV
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
Samsung LCD TV 26
If you have not tried it you may want to see if the voltages listed come up with boards disconnected from the power supply one at a time---This could be anywhere from micro to the panel.
Mar 25, 2012 | Televison & Video
The tv will not switch on at the on/off it flashes green makes a clicking sound then the light goes red and flashes slowly at intervals
sounds that you may need to get a service repair for it, but try to turn it off, then unplug it. press the on/off switch for about 10 to 15 secs while unplugged, then wait for about 1 to 2 minutes, plug it back and test it again.
Jan 17, 2011 | Televison & Video
On start pump runs for 2 secs then nothing for a min then try's again. spin end light lit
sounds like the timing control connections are worn or dirty. i would unplug it or flip the breaker, and look there first. check for continuity on the various contact points with a multimeter. Red wire/probe of the meter goes on the black or "line in" " "120V". this tells you if it is making good contact as the timer control spins around.
Oct 07, 2010 | Washing Machines
TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Nov 03, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Power keeps surging and won't stay on
I will need the model number of your set in order to make any suggestions as to what possibly could be causeing the problem
May 17, 2008 | Hitachi Televison & Video
EXPOBAR Office Control Espresso Machine Logo
43 people viewed this question
Top EXPOBAR Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you an EXPOBAR Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
