Question about Lexmark X4270 All-In-One InkJet Printer
Fax has lines in it sometimes
I have this printer connected to my computer for work. I can fax the print fine and then the very next time i fax the fax goes through with lines on the right side of the page top to bottom. I will refax it and they recieve it with no issue.
  • 186 Answers
Open the cover where the original feeds in, and check the little glass and see if there is any white out or dirt, ink. Clean it off and try it again!
Posted on Jun 22, 2007
SOURCE:
Brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Dec 14, 2011 | Brother MFC 7840W Printer
Attempting to FAX...ErrorCode OxAF8D...cannot find this code in manual.
Where do you initiate faxing - from your computer or using the printer operator panel?
Try the following steps to determine what is causing this problem:
  1. Disconnect the printer from the phone line from the wall.
  2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  3. When the printer turns on, try to make a copy or print from your computer to verify that the printer is working normally without connecting to the fax line.
  4. If copying or printing from computer is working properly, then connect it to the fax line.
  5. Try to send a fax from the printer operator panel.
  6. Try to send a fax from your computer. If error appears, try to update your printer software by inserting the printer's installation disc into your computer hard drive.
I hope this helps.Please keep me posted.
Nov 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have a Lexmark mode lX3550. What do I have to do to make it fax?
Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. • The Lexmark Fax Software is installed on your computer.
Sending a fax using the software You can scan a document to the computer and then fax it to someone using the software. 1 Load an original document facedown on the scanner glass. 2 From the desktop, double-click the Lexmark Imaging Studio icon. 3 From the left pane of the Welcome screen, click Fax. 4 Select the Document option. 5 Click Start. 6 Enter the recipient information, and then click Next. Note: A fax number can include up to 64 numbers, commas, periods, and/or these symbols: * # + - ( ). 7 Enter the cover page information, and then click Next. 8 If there are any additional documents that you want to send with your fax, add these now, and then click Next. 9 To send your fax: • Immediately-Select the Send now option. • At a scheduled time: a Select the "Delay sending until" option. b Set a time and date. 10 If you want a paper copy of your fax, select Print a copy of your fax. 11 Click Send.
Aug 11, 2011 | Lexmark X3550 All-In-One Printer
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
Problems with sending and receiving FAX
HP FAX ISSUES
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
Using a Lexmark 3400 series to fax
Yes your printer will send and receive faxes. 1. Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 Load an original document facedown on the scanner glass.
Here is the manual, in case you don't have one http://www.retrevo.com/d/ds/progress?doc=7d2128cd89431b0e3d4c2a1c31fa8fc4
3 From the desktop, double-click the Imaging Studio icon. 4 Click Fax. 5 Click Scan and send a fax. 6 Click Preview Now. 7 Click and drag the dotted line box to select a specific area of the preview image to fax. 8 Adjust the settings as needed. 9 Click Next. 10 Follow the instructions on the computer screen to complete the task. Receiving a fax using the software 1 Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. 2 From the desktop, double-click the Imaging Studio icon. 3 Click Fax.
Dec 05, 2009 | Cars & Trucks
IntelliFax 4100 suddenly slow to print
If the dial tone sounds NOISY or SCRATCHY there probably is a phone line problem. Try changing the phone cord first. Are you using DSL phone service?
You have a very reliable fax machine.
Nov 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Faxing
You need Option, AR-FX7 (FAX) installed, real easy to figure out, look at the side, if you see a telephone line, with line and telephone connections (not the Network connection) then you have a fax.
Next your arm237 will also need to be able to print from the nextwork.. if this is all together..
you will need a driver called, PC to Fax for the AR-M237.
which you can find at www.sharpusa.com
Then you will have to set up the computer in the printer folder to PC to Fax.
Sep 29, 2008 | Sharp AR-M237 Copier
Printer quit working
try a test page first to determine that the printer has basic abilities.
http://tinyurl.com/6qcpgy
Aug 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
I cant print with my lexmark printer, it is a type x2480 every time i go to print it wants me to set up a fax line please help me
Check your printer properties to make sure it is set to print using the proper port. If it is set to 'print to fax' it will attempt to install a fax line every time you try to print. It should be set to your LPT (printer) port or your USB port, depending on how you have it connected to your computer.
Mar 18, 2008 | Computers & Internet
Lexmark X4270 All-In-One InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
