Question about Troy Bilt 5.5hp Self Propelled Mower
Snapper electric start snow thrower won't start
Snapper electric start won't start. it turns and then stops. then again and again after waiting a couple of mins. HELP please i have a ton of snow
  • 641 Answers
If the engine has a float type carburetor, remove the float cover and see if the float is hung in the down position. If so free it up and make sure it will now operate freely up and down. If not and the bowl is full of crud, you will have to remove and clean the carb.
Posted on Mar 13, 2009
  • 74combs Jan 21, 2011
    Primer hose off were go
    Problem Solver:
  • 7 Answers
If it is stalling, first change the plug as it could be flooding because you do not have hot enough spark. Never hurts to change plug anyway. Make sure you gas is good if it is old this could cause this..
Another thing to check is if you have spark and it starts and stall right away you could have a bad key under the flywheel . if this is broke it will throw the timing off. a good way to check this is this, take out the plug and remove the cover around the flywheel. this is the cover that has the rope on it. after you remove the flywheel cover and the plug you can stick a pencil in the cylinder where you took out the spark plug, then turn the flywheel by hand and as the magnet turns by the coil or magneto your pencil should come out of the whole indicating the piston in the up posistion. When the magnet on the flywheel passes the coil this must be on the up stroke of the motor or compression stroke so to say. when the magnet passes this is what causes to plug to fire. If your key is broken the flywheel will slip and it may try to fire when the piston is not all the up(timing off) the motor will never run. This is a fairly simple job and should only take an hour or so. you may need a wheel puller to do it or be very careful.
good luck
Posted on Jan 20, 2009
    I have spark but it won't start
Sears model 1150 snow thrower how repairing the electric connecter for sears model 1150 snow thrower
It's just a simple AC pronged piece. You can buy the actual piece from Sears OR you can buy an Electric Line-cord and wire it into teh plastic box where the Push button 'Start ' switch is.
Mar 01, 2015 | Garden
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
Snow Thrower Won't Start. I have a Sears 26" Snow Thrower Model No 247.889702. It will not start. Changed fuel, new spark plug, propoerly primed the engine, tried both pull start and electric star
does it have spark? if you can start it with starting fluid chances are the carb needs a good cleaning or replacement. fuel these days goes bad in about 2 months without stabilisers in it. gums up the tiny passages in the carbs. i suggest seafoam as a treatment but anything is better than nothing...good luck
Nov 18, 2017 | Garden
Toro snowthrower 38180 won't start
You have probably fouled the spark plug (got a heap of black carbon on it) remove the spark plug wash in some petrol then use a wire brush vigorously brush between the contact points on the plug then reinstall. & lastly don't forget to push in the choke when you get it fired up next time.??
Mar 14, 2017 | Garden
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Troy Bilt 5.5hp Self Propelled Mower Logo
757 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
