Question about Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer
Washer not working properly
We have a Frigidaire FTF2140ES0 front-loading washer. When you push the start button, it beeps once like it should, then when you push it the second time to lock the door and start the water, all the lights come on and it beeps three times. We replaced the door lock, but that didn't help. Then the parts guy told me it needed the control panel, so he ordered it. When it came in, It looks like mine all except that my machine's control panel has a place for the reed switch to plug in and the new panel doesn't. We went on and put the board in the machine and it seemed to work fine at first. The door locks and water comes into the machine, but it only runs for about four seconds. Then the machine sits still, humming low for about two minutes and then it repeats with water running in for about four seconds. It has been continuing this process for about 10 minutes now.
Is the missing reed switch on the panel the problem? Should I return the control panel and try something else?
  • Cindy Adams Apr 13, 2009
    For anyone with this issue, it was the main control panel that the knobs fit on. I paid about $140 for the board and put it in myself.
    Cindy
    Problem Solver:
  • 3 Answers
The reed switch has been removed from the newer washers of same model. Nothing to do with the switch. Open door and turn the drum. This has happened to me a couple times. If the drum will not turn , try putting a little force on it. Mine acted the same and it was a sock that was stuck. Didn;t know what it was until I removed the boot where the coin trap is . and found a sock hanging down from the tub. stick your fingers up it the tub( with washer unplugged) and check for any material that might be there.
Posted on May 23, 2009
Frigidaire FTF2140ES0 Front Load Washer lock indicator light goes off, but will not spin.
Sounds like the electronic locking mechanism is malfunctioning. It is supposed to enguage before the high spin cycle. It is about a $20 part.
Sep 20, 2011 | Frigidaire GLTF2940ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
Jan 04, 2010 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
FTF2140ES0 Bellows Kit replacement
remove and install a new bellows kit for a Fridgidaire front-loading washer model ftf2140es0
Nov 09, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Need a restart code
Press & hold down the 'options' & 'select' buttons for over 3 seconds. And let me know. These are the buttons, but how long?
Mar 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
FTF2140ES0 Frigidaire Washer Won't Start
Yes - often times the plastic breaks from slamming the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Washing Machines
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer Logo
333 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
