Question about Sewing Machines
Bernina Deco 650 Top thread is winding around the bobbin
I have a Bernina Deco 650 that I bought used about 5 years ago and I pulled it out today to use it for the first time. I am doing redwork christmas designs on muslin. The top thread keeps getting wound around the bobbin and the machine stops and I have to cut the fabric to get the hoop off. Any suggestions? What thread should I use (top and bobbin), what stabalizer should I use. This is going to be put into a quilt.
Thanks
  • alibritt37 Jan 17, 2009
    I did use stabalizer. I called the Bernina dealership which is about 60 miles away and she thought I wasn't threading it properly and the tension wasn't engaging....whatever that means. Ooooo, I am so frustrated! I am going to get an embroidery needle for it. Maybe I wasn't threading it with the needle up (or down?). It started off making two pretty snowflakes and when it was about to start Snoopy it just went to the dogs!!!!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
You should use some klnd of stabilizer under your hoop. I use the paper kind which is thin or there is a heavier tear away stabilizer. I have used all cotton thread for embroidery or you can use rayon. There is a finer thread called bobbin thread for the bobbin but I gernerally use the same as on the top so it will be the same. Are you using an embroidery needle? .As for your thread getting wound around the bobbin the only thibng I can think of is tht it is threaded incorrectly. if it isn't the lack of a stabilizer. I hope this helps but I think it the the lack of stabilizer that is causingyour problems. The needle is going in and our of the same hole during embroidery and is getting stuck on your bobbin. Let me know if this helps! Suz
Posted on Jan 17, 2009
My bottom tention of Bernina Deco 340 is to loose. How to I correct is. The top treat shows to much at the bottom
Um, the top thread is showing on the bottom of the fabric? The top tension is too loose. The two threads create a tension battle, one pulling against the other. To pull the bobbin thread up, tighten the top tension. The tension is accurate when the two threads meet "in the middle" of the fabric. On thinner fabric, you might see a tiny spot of bobbin thread on the top and a tiny spot of top thread on the bottom.
Aug 24, 2017 | Bernina Sewing Machines
Why does the top thread wind around the bobbin on my Deco 650
try using a can of air in the bobbin area, also check for lint or loose threads, make sure the bobbin is turned correctly in the bobbin case, try a different bobbin.
Dec 02, 2014 | Sewing Machines
Bernina Deco 650. won't stitch
You need to take the machine to a Bernina dealer for service. It may just need the timing adjusted, or there could be something else that needs to be done.
Apr 19, 2010 | Bernina Bernette Deco 600
Bernina Deco 650 Check if upper or lower thread is cut shows on
turn machine off and on to see if message clears... not sure for that machine ( I work with Brother products) but if it has a wiper (small hook shaped blade) that trims the tread automatically it may be stuck in the extended position
Apr 08, 2010 | Bernina Bernette Deco 600
I own a Bernina Deco 340. While winding the bobbin, The thread keeps wrapping around the bobbin post
I have that machine. Either the bobbin isn't all the way down on the bobbin winder or the thread isn't under the top part of the bobbin winder guide. These must be plastic bobbins.
Jan 16, 2010 | Sewing Machines
Just got my used Bernina deco 650 from the shop. Tension off
The tensions are not calibrated properly. To get by, or if you do not want to take it back to the shop, just lower the upper tension a little at a time until it looks ok.
I have 25 years experience working on sewing machines
Jun 29, 2009 | Bernina Bernette Deco 600
Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Nov 17, 2008 | Bernina Bernette Deco 600
Top color thread showing on bottom of embroidery on a Bernina Deco 330 embroidery machine
Upper tension is too loose or lower tension is too tight.This might be a good thing. It depends upon how much it is pulling the thread under. A perfect tension on embroidery is about 2/3's lower thread and 1/3 upper thread showing on the bottom.
sewman7
Jul 09, 2008 | Bernina Bernette Deco 600
Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
May 19, 2008 | Bernina Bernette Deco 600
Sewing Machines Logo
317 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
