Question about HP Hewlett Packard Pavilion a6130n PC Desktop
Running Vista system restore 8hrs (not in safe-mode)
Looking for a better solution. Is their safe way to stop system restore and put the computer in safe-mode and then restart system restore?
Or can you recommend a better solution. Took rstore point to 5 days back. Appreciate any help. Thanks.
    President:
  • 2,692 Answers
I am fairly sure that if you stop the system restore mid stream it  will just resort back to where it was w/o any problems.  Then you can restore in safe mode. If it took that long ,if I were you , i would go and clean the harddrive or run check disk or download hard drive tools from;    seagate.com      and check the hard drive .  Your other option is to use you restore disk and restore the whole thing. If the hard drive is bad you will ending up doing this after you install a new hard drive.
Posted on Jan 17, 2009
Cannot access my computer up date windows vista (TM) BUILD 6000 has caused an error code 0xC004E002 i'm running vista home basic
Try doing a System Restore and choose to restore the system to a date when in was working successfully last, or maybe just before then:
Boot into Safe Mode, then go Start, All Programs, Accessories, System Tools, and then choose System Restore. Once the System Restore is complete, let the system boot normally and see what happens.
Dec 15, 2011 | Cell Phones
"I was recently downloading something
Go to Malware Bytes and download the free malware scanner. That will find pretty much any virus that infects a computer.
Jun 02, 2011 | Toshiba Computers & Internet
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
All of a sudden when I turn my computer off then on again I have to reboot my system using my os dics Im using vista
This is unclear. You most likely need to put the computer into safe mode and undo what ever was done. Read this link to get the compuetr into safe mode and the secone one for system restore.
http://windowshelp.microsoft.com/Windows/en-US/help/323ef48f-7b93-4079-a48a-5c58eec904a11033.mspx
system restore
http://windowshelp.microsoft.com/Windows/en-US/Help/517d3b8e-3379-46c1-b479-05b30d6fb3f01033.mspx
Good Luck,
Sagacious1
Aug 07, 2009 | Computers & Internet
Acer asprie 5315 running xp sp2 system restore wont work,cant perform a system restore.
Boot to safe mode by pressng F8 as soon as you start the system,
Once you are in safe mode. try to access system restore. In safe mode you will get access to the system even if it faces a severe error.
If it is complete system restore (Restore to factory defaults) which you are looking for then press ctrl+F11 as soon as you start the computer. It will wipe the entire data and restore the system to its factory settings wiping out the entire data in the system.
Jul 12, 2009 | Acer Computers & Internet
Acer loops booting
The problem is caused by bad drivers not being able to load up, when you are in safe mode perform a system restore and take the computer back to a date before the problems arose, the computer should boot up fine once system restore is complete.
Good luck
Jun 22, 2009 | Acer Veriton M410-UD4000C Athlon 64 X2...
I have a Toshiba pc satellite a105-s4284 when you log on it logs off. wont run on safe mode
if you have a cd that came with the computer if its vista or xp your running you can always put the cd in and use system restore to restore your computer to a earlier time or when you start the computer up there should be a button you can press, it tells you on the screen to start system recovery from there you can use system restore to restore it maybe restoring it to a earlier time will help or you could try going into safe mode and using system restore just some options you can try
Apr 17, 2009 | Computers & Internet
Windows Vista system restore keeps running (8hrs)
Press F8 as the laptop boots up, instead of selecting boot in Safe Mode, select Last Good Known Configuration.
With luck it will return to normal.
Jan 17, 2009 | Compaq Presario X1000 Notebook
Hello. I am running vista home ultimate 64bit. Manually I am unable to create a restore point. Error message 0x8004230F unexpected error for shadow copy provider. I have check in the computer management...
Sometimes, Windows Vista Ultimate 64bit will not allow to create a restore point as it is self scheduled to create its own restore system restore points.
To over-come this: turn the system off, press the on button and keep pressing the F8 button to get into Safe Mode. Once you are in Safe Mode, go to the System Restore and then create a Restore Point. Once you have done this, shut down and restart the system, you will then see your restore point that you have created.
Hope this helps
PC Software Solutions PLC
pcsoftwaresolutions@techie.com
Dec 06, 2008 | Computers & Internet
Toshiba Satellite Vista operating system not running.
if you did installed soneting just uninstall it hardware or programs then restart the computer all these you can do it on save mode
Jan 01, 2008 | Toshiba Satellite A135 Notebook
HP Hewlett Packard Pavilion a6130n  PC Desktop Logo
334 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
