Question about Dryers
Re: Heating element
Looking for some help. I recently replaced my heating element in my dryer and worked....worked well for ohhh about 10min. Now my dryer wont even start. Nothing. Air Fluff/ Perm Press/ Timed...NOTHING! Any suggestions?
Greg
  • 5,911 Answers
Did you verify that your ventilation was cleaned and free of obstructions before replacing the heating element? Leaving a dryer in a condition where it has poor air flow can cause the dryer to overheat and cause failure of additional components. Most commonly, this problem is caused by a blown THERMAL FUSE (in some models this is called a THERMISTER), which is generally located on the air blower housing inside the dryer.
What is the MAKE and MODEL number of your dryer? Is your heating element in the back of the dryer, or accessed through the front under the drum? The following link can give you some more information and a starting point to troubleshoot:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Read through the link thoroughly and PLEASE let me know if you have questions. I hope this helps you.
Posted on Jan 18, 2009
Dryer was not heating replace heating element, how dryer still does not drying looking at wire legend and found two thermal fuses how can i check fuses.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | GE Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
New heating element not working
You should check to see if the "high limit switch is burned out. Some models/Brands have 2. It should be on the outside casing of the heating element.
Apr 30, 2010 | Estate EED4100SQ Electric Dryer
I am looking to replace the heating element on an old hotpoint electric dryer and cannot locate how to find it.
Depends when the dryer was made, older models had the element at the front behind the front panel.
More recent models all have the element located at the rear of the dryer..
Hope this helps.
Dec 29, 2009 | Hotpoint Dryers
How to replace heating element on dryer model #96282100
This is a fairly simple procedure. Just follow these steps:
1. UNPLUG the dryer. Dangerous voltage is still present even with the dryer turned off.
2. Turn the dryer around so you can access the rear and remove the exhaust vent hose.
3. Locate and remove the screws around the perimeter of the dryer back panel and remove panel.
The dryer heating circuitry will be located on the right hand side (as viewed form the rear). The heating circuits consist of the following components:
Heating Element - (part number 660982)
*Thermal Cut-Out (TCO) - (part number 279769 includes the Hi-Limit Thermostat).
*If either the TCO or Hi-Limit Thermostat is determined to be defective it is recommended that you replace BOTH parts at the same time. That's why they are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
The heating element is located inside the heater box. The TCO is located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit thermostat will be located adjacent to the heating element terminals.
Searspartdirect.com has an excellent exploded view diagram of all these components. Just type in your model number and locate the following under the "bulkhead" section:
TCO/Hi-Limit Thermostat - Item 1
Heating Element - Item 14
Hi-Limit Thermostat (by itself) - Item 34
The reason I mention all these components is because if you have not confirmed the heating element to be defective, you may actually have a blown TCO or Hi-Limit Thermostat. Its easy to assume a bad heating element if the dryer fails to heat, but it may or may not be the cause. Just some additional things to consider, that's all. These components cost less than a heating element too. If you have determined the heating element is bad, then continue with the following:
4. Disconnect the leads to the heating element and locate the screws that hold the heater box in place.
5. Locate the screws on the outside of the heater box that hold the element in place. You may also have to remove the TCO and Hi-Limit Thermostat.
6. Once the screws are removed, the heating element will slide out of the heater box. The element fits tight and it may require a little effort.
7. Once the defective element is removed, install the new one by sliding it inside the heater box. Make sure you align the screws holes.
8. Reinstall the remaining components and reinstall the heater box.
The rest is self-explanatory.
NOTE: A good heating element will read approximately 9 to 13 ohms. Make sure you disconnect any leads before taking any measurements to ensure accuracy of your readings.
The following link explains a good portion of what I've already explained to you, but it may help as well:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention the section that discusses proper air flow. The majority of all dryer heat related problems are attributed to poorly installed, kinked, clogged or crushed exhaust vent ducting. If you haven't thoroughly inspected the dryer and ducting recently, now may be a good time to do so. Otherwise, any components you replace will fail prematurely. Not to mention, a clogged dryer is also a fire hazard.
If you have any questions, please let me know. I hope this information is helpful to you.
Oct 20, 2009 | Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
Clothes Dryer Doesn't Heat
Check for a blown thermal fuse or faulty heating element. Both components can be checked using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. Hope this helped and best wishes.
Aug 08, 2009 | Dryers
Kenmore Elite He4 Dryer Model Number 110.85872400 won't heat up and dry clothes; husband thinks it is the heating element but is having a hard time gett it out
Before assuming you have a bad heating element, read through the following link:
Most dryer heat related problems are attributed to poor ventilation which, in turn, causes the dryer to overheat to the point of failure. More commonly the Thermal Cut-Out (TCO) fails. The component acts as a fuse and must be replaced if bad. In addition, if the TCO is determined to be defective, it is recommended that you replace the Hi-Limit Thermostat at the same time. Both these components work in conjunction with the heating element and are mounted on the heater box. The TCO is located on the end opposite the heating element terminals. The Hi-Limit Thermostat is located adjacent to the heating element leads. These two components are often sold as a kit. If you fail to replace both of them you can experience premature failure of the component you do replace.
Pay particular attention to the section that discusses proper dryer ventilation. If you haven't checked or cleaned the exhaust ducting any time recently, now might be a good time to do so . A dryer left in a clogged or poorly ventilated condition will cause repeated failures in the heating circuit. Not to mention this creates a fire hazard.
If you read through the link and determine that you have a bad heating element, follow these steps to remove:
1. Unplug the dryer and remove the lower panel under the door.
2. Remove the lint screen from the dryer door.
3. Remove the blower fan housing vent cover.
4. Disconnect and label the component wiring on the heater box.
5. Loosen the mounting screw on the heater box front support.
6. The entire heater box, with element inside, should slide out of the dryer.
7. There should be a couple of mounting screws on the component side of the heater box that you need to remove and the entire element slides out.
If you still have questions, please let me know. I hope this helps you.
Jun 12, 2009 | Kenmore Elite HE4 Electric Dryer
Replacing heating element
Hi NoNicky. I do not own a Maytag, but did find information about it on a couple of sites I've used before for my Kenmore. I'll include an image that should be for your model (they list MDE7500AYQ and MDE7500AYW). There are also details on the steps needed to gain access to the dryer and a diagram of the heating subsystem. Kenneth P.
Jul 27, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
