Thin white horizontal lines across top of TV
Is it worth repairing ~8 years old JVC K-series 29" TV. If the screen is receiving 16x9 theater broadcast, lines are not at the top of the screen. If it's a standard tv show full screen, about ~10 white lines appear, not real bad, but enough to be annoying.
Stationed in Europe and not sure if to purchase Flat Panel and worry about shipping it back when returning to U.S, or to hold off and just fix this one to last ~8 more months
  • Anonymous Feb 20, 2009
    i have white thin lines from top to bottom on my tv screen and the picture looks like it's sorta white like when water is white before it turns clear.
  • kornegays Mar 06, 2009
    Cost about $65 and works. Thank you.
    Sergeant:
    Champion:
  • 346 Answers
Replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Posted on Jan 17, 2009
I have a JBL home theater system that is about 8 years old. The sub woofer is independently powered with an ac line and now intermittently has static/white noise that comes and goes without any apparent...
Its probably electrical interference. You are better off replacing it, or borrowing a friends sub and hooking it up. Just to make sure it's not your reciever or any wiring.
Mar 14, 2011 | Audio Players & Recorders
Good Morning\r\n i have a JVC Interiart 29" Flat screen tv which is 8 years old which has started making a noise when switched on,a very loud humming noise and no picture for a couple of minutes then the...
That usually indicates a capacitor going out in the power section or flyback section of the board inside. Depending on your repair shop this can be a fairly cheap repair (or not). Get an estimate and know what a replacement tv is worth. Sometimes its cheaper to get a new one than repair the older tv. As well power problems can stress other parts so it might get fixed only to fail later.
Jun 14, 2010 | Televison & Video
Picture will not fit screen
a couple of questions here 1st.
1) what are you displaying or what is your source?
a) Regular off air TV
b) Cable TV
c) DSS Satelite
d) DVD
2) Please bear in mind that the new TV's will format your screen to either fill it's screen ' if you choose this feature' with what ever you wish to display or it will display the appropriate image of what it is receiving.
You may have just an off air anntena which still recieves old TV reception '4x3' aspect. The new digital TV is now a '16x9' aspect but your old off air antena may not be able to pick this signal up.
Please be aware that your new TV may be able to display the 16x9 at over 1,000 lines of resolution from top to bottom of your screen. Older TV or off air was only 4x3 and just under 300 lines of resolution from top to bottom.
Nov 19, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Screen goes to horizontal line
Maybe the vertical IC got some cracked solder joints and the reparation worth it
Apr 24, 2009 | Televison & Video
JVC TH-C30 Digital Theater System
If there is no power at all, then try bypassing surge protector, check power cable, and check if power cord is fused.
If unit has power but does not start, then it is on protection.
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 11, 2009 | JVC SP-PW100 Subwoofer
How much is a JVC RX 750v worth?
I have this same unit. It is many years old, and does not handle any modern codecs, nor home theater duties. It was, however, a very good unit for its day. If I were to sell mine, I would not accept less than 100 US with remote.
Nov 11, 2008 | JVC RX-664V Receiver
Hi, I have a Panasonic XF Series 31" TV, manufactured in Nov. 1994, Model CT31XF4OR. The TV randomly goes from a full screen picture to a single line, about 1/2 inch wide in the center of the...
Sounds like the picture tube is starting to go, I don't believe it would be worth repair or even if you can get the parts for a tv that is almost 15 years old, time to buy a new one.
Oct 09, 2008 | Panasonic Televison & Video
JVC TV - BLACK HORIZONAL LINE ACROSS THE TOP OF TV
The vertical circuit is not pulling the top of the picture to the top of the screen (CRT) correctly. Its possible you have a loose wire or device ( after moving ) . If you have vertical agustments on the back , you may be able to adjust the picture taller; if the picture becomes stretched ( non - linear ) then you definately have tv tech only problems. At that point I'd really think twice about a repair and consider a new DTV or HDTV set. If the unit was damaged by a mover , then you may have a claim against them .
Apr 30, 2008 | JVC AV-27D305 27" TV
Television fault
it is not worth fixing get a new tv
Oct 31, 2007 | JVC AV-27020 TV
Televison & Video Logo
775 people viewed this question
Top Televison & Video Experts
Electro Med Services...
