Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
I have a sony wega 20" and I have to press the power button 15 to 20 times to get the tv to actually power up. It clicks and then clicks off then clicks again.
  • frinzdon Feb 05, 2009
    please send me a solution if you find one email ad is frinzdon@yahoo.com
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please intimate exact model of TV and how old is this TV?
    Genius:
  • Sony Master
  • 1,689 Answers
The main power supply or the scan circuits are staring to fail. Considering the cost of service for this type of fault, I would consider to start shopping for a new set.
Jerry G.
Posted on Jan 17, 2009
Hi? My Sony Projection T.V model KP-FX432M91 is taking time to power on and once it has powered on it work fine.what might be the problem?
Power button may need to be replaced. Try turning on via remote.
Some TVs need to warm up before coming on. Hitting the power button several times may in all actuality be Turing it off and on.
Sep 20, 2016 | Sony Kp-Fx432M91 43" Projection Wega...
I have a Sony FD Trinitron Wega (KV-32HS510). When I attempt to turn the tv on by pressing the power button on the remote or on the tv, the standby light comes on and I hear two clicks but tv don't...
The primary power supply is good,maybe the horizontal output transistor is deffective thats why there is no high voltage supply in the picture tube because theflyback have no supply voltage and oscilation.So check the harizontal output transistor and replace if deffective.
Sep 12, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The TV keeps going into standby mode , comes back to proper picture and with-in 15-20 seconds goes back into standby mode. It happens continueously.
May I know if the standby led light at the front panel is blinking, if so please count how many times it will flash to determine the error code? If not follow the steps below.
In standby mode press the button of the remote control in sequence, " Display ", " Channel 5 ", " Vol (-) ", " Power ". Self diagnosis screen will displays. Le me know the result.
Jdvillanueva
Sep 02, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
Reset lamp hours on sony grand wega
hello
  1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
  2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
  3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
shaun
Nov 05, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Feb 01, 2009 | Home Security
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony WEGA KD-34-XBR960
    Push display - 5 - vol + or - then power. Clear CH setup if there and if the right numbers are not zero the push 8 then enter, that will clear the numbers, like reset. IF unit no workie the start up that way and any zero with numbers are what the units problems are.
    BC
    Oct 13, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    Sony Trinitron TV takes multiple manual clicks to turn on.
    If you mean the actual mains switch needs multiple cycles, it could be faulty.. does anything, say a power indicator, come on when the TV doesn't?
    If the actual switch is OK, then you probably have a fault in the power supply section... often faulty electrolytic capacitors. U need service.
    Mar 26, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
    Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
    62 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
