Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Model 110.44832 200. overflow F09 error wtr enters when off/unplg
I got an F09 error and overflow. Huge overflow! There was a drain problem, and I cleaned it out. (there was a 5 dollar bill in it) Even though I turned the machine off and unplugged it water still flows in. I had to turn off the water at the outside valve. Could the large volume of water have damaged the water intake valve or the logic board? I'm going to dry it out and see if it resets itself when I turn it on. If it doesn't can I fix it myself? I hate this machine. It has been nothing but trouble.
  • 84 Answers
It sounds like the water inlet valve may have jammed open , see if water still enters when machine is switched off if it does not then you probably have a short on the electronic module.
Posted on Jan 29, 2009
Error code F09 for whirlpool
F09 Overflow condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check for Drain Pump Failure
• Check the Inlet Valve for proper shut off
• Check the Pressure switch for proper operation
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2e96NFcLn
Sep 06, 2013 | Washing Machines
Whirlpool duet f09 error code
it is an overflow condition caused by either a plugged drain pump or a bad pressure switch,if you hit pause/cancel and the drain pump continues to run then check the drain pump cleanout for foreign objects
Aug 31, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F09 in a AU AWO 5761
F09 Error = Overflow Condition
Potential Causes
• Check/ Clean Drain Pump Filter of foreign objects
Dec 29, 2010 | Whirlpool AWM8143 Front Load Washer
Whirlpool awm 8142 faul code f06 ja and i start it again, the new fault code f09 and the machine stops... whats wrong whit it!
F/06 error code, Drive Motor Tachometer Error
F/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
~Check the drain hose and make sure it is not plugged or inked.
~Check Wire Harness connectors to the Drain Pump, Pressure Switch, and ~Central Control Unit (CCU)
~Check/Clean Drain Pump Filter of foreign objects
~Check for Drain Pump Failure
~Check the Inlet Valve for proper shut off
~Check the Pressure switch for proper operation
Nov 15, 2010 | Whirlpool AWM8143 Front Load Washer
F-09 error code
Hi
F09 error occurs due to overflow condition, if the overflow contact on the pressure switch is closed for more than 60 seconds and overflow condition will occur. To start with check the drain hose and make sure it is not clogged, also try to clean the drain pump filter. If everything is fine and the drain pump is running then check the wire harness to the drain pump and control unit. Please post a comment if you need more help.
Thanks
Rylee
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The machine is not filling with water than it shows F09 and then FA on screen. Its a 6th sense and about 4 years old
Error F09 means Overflow Condition
Thank You
Sep 06, 2010 | Whirlpool Washing Machines
F09 code on front load washer. What is this?
F09 error means Overflow Condition.If the Overflow contact on the pressure switch is Closed for more than 60 seconds,Overflow condition will occur.In an Overflow condition,the Door will remain locked and the Drain Pump will run constantly,even if Pause/Cancel is pressed twice and the Display is cleared.
1. Check the drain hose and make sure it is not plugged or inked.
2. Check Wire Harness connectors to the Drain Pump,Pressure Switch and Central Control Unit(CCU).
3. Check/Clean Drain Pump Filter of foreign objects.
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off.
6. Check the Pressure switch for proper operation.
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F09 displayed on the machine
Hi!
F09 code on your whirlpool means---
Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly. Try pressing PAUSE/CANCEL twice to cleaar the Display.
If display doesn't gets cleared then check for---
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump.
  • Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
Please rate this solution as Fixya if found useful.
Please ask for any clarifications.
Thanks
Rylee
Mar 14, 2009 | Whirlpool Washing Machines
F09 Error
This is what F09 means
Condition
Overflow Condition
Check and repair
  • Check the drain hose and make sure it is not plugged or inked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
Dec 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sears Kenmore Elite Front Loader Washer F09 Error 110.42832 200
Okay...you probably already know this, but here it goes. F9 is an Overflow Condition. If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. This is verbatim from the tech sheet. You will need to check to following: 1. Check the drain hose and make sure it is not plugged or inked. 2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU). 3. Check/Clean Drain Pump Filter of foreign objects 4. Check for Drain Pump Failure. 5. Check the Inlet Valve for proper shut off 6. Check the Pressure switch for proper operation. Now, I don't know if the repairman had anything to do with this problem or not. If he didn't mess with any electrical connections, then this may strictly be coincidence. If you've only been checking the drain pump for foreign objects, you probably need to check some of the other items mentioned. 1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. Could be you have an obstruction somewhere. Be sure to check the hose just prior to the drain pump as well. This is the hose on the bottom of the tub. This area can get clogged with debris. (Also, to prevent from making a huge mess the next time, try using this procedure to drain the washer from the machine BEFORE you remove the pump cover). 2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the rear of the washer with all the wiring running to it). Could be you have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. I don't know if this will generate an F09 error, though. 3. The drain pump. If it's running and you've already checked it for foreign matter, the pump is probably not the problem. 4. The inlet valve. You can check them if you like, but an overflow condition would indicate the presence of too much water. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time. Could be running water or a small trickle. Do you find standing water in the tub when not in use? 5. The suds error. This occurs when air from too much detergent gets into the drain line. I know you say you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider: a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use. b. Look at the detergent container. Is it double concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds. c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing. Rule out the simple common sense things first. When everything else checks out and your problem still persists, you may have some concern (usually the CCU or pressure switch). I hope I'm not insulting your intelligence, and I hope this helps you in some way.
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
168 people viewed this question
Sal De
fordexpert
Robert Rankin
