Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Dishasher does not drain
Dishwasher seems to work fine but does not drain i have checked all drain hose and drain pipes heir are no obstructions but it still does not drain i have disconnected the drain tube from drain and water will then drai out of unit but this is only from gravity
  • 2 more comments
  • eric ortiz Jun 26, 2007
    not hooked up to disposal it runs on its own drain and all is clear
  • eric ortiz Jun 28, 2007
    how can i tell if the pump is working or not thats what i would like to know
  • Anonymous Dec 06, 2007
    dishwasher will not drain
  • jditonto Dec 08, 2008
    same problem...any ideas?
I havejust installed a new frigidaire dish washer on the first cycle it will pump the water out but not on the final cycle
Posted on Dec 27, 2008
    Problem Solver:
  • 4 Answers
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Posted on Oct 28, 2007
SOURCE:
Dishwasher repair. Problem: water in bottom of machine, not draining/ cannot select any mode other than 'Auto'/ usually does not start. What happens when I try to run it: Switch on. On switch lights
I had a similar issue. I took off the drain hose, ran hot water thru it and removed the hose going into the garbage disposal there was some built
build up on the inside, cleanness it good put through houses back together and everything was fine. Hope this
Dec 23, 2014 | Dishwashers
DISHWASHER WILL NOT DRAIN PLUMBER WAS CONTACTED DRAIN LINE IS FINE LOOKING FOR OTHER CAUSES? THANKS, SEAN
Can you hear the pump trying to drain it? If you can then you have a blockage. Try blowing hard down the outlet hose, what happens? Have you checked all filters?
Mar 06, 2011 | Frigidaire FDB1502RGS Built-in Dishwasher
Hi, I have a 10yr old Neff s5543 built-in dishwasher, it is has been working fine but recently has stopped fully draining. I have removed it from the housing and checked all pipe work is unblocked and...
Hello there and thank you for choosing fixya
Ok there are acouple of things that can be checked on this along with what you have already checked
Drain solenoid Beneath some dishwashers, there's a timer-activated drain solenoid (an electro-magnetic coil) that opens a drain valve, to drain the wash water through a hose and out to the house's plumbing waste system. If this is failing it will not allow the water to drain from the machine fully
Timer Dishwashers have a timer behind the main control panel at the front top of the dishwasher, or behind the lower access panel. It is either a mechanical device like a simple clock, or it's completely electronic with just a digital readout. The timer runs the dishwasher in a pre-determined pattern. It provides the electricity to all of the dishwasher components at the correct time, for the correct length of time.
Oct 16, 2010 | Neff 24 in. S5543X2 Built-in Dishwasher
MY FRIGIDAIRE DISHWASHER WILL NOT DRAIN. MOTOR ONLY HUMS DURING DRAIN CYCLE. OTHER THAN DRAINING IT SEEMS TO WORK FINE. DAY IT QUITE WORKING SINK BACKED UP AND WOULD NOT DRAIN
if there is still water in the dishwasher take the drain hose off from under the sink and use a large pot or mop bucket and but the unit into a drain mode usually by cancelling the wash cycle if the unit still does not drain.Then use a wet dry shop vac and attach it to the end of the drain hose to remove the water
after the water is gone check the drain pump for any kind of obstructions you may need to replace the drain pump
Jun 06, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
WHAT IS F11 ERROR MIELE DISHASHER G 1232 SC
hi
this is a drain fault. you will probably find the drain spigot under the sink is blocked where the drain hose connects.
Dec 13, 2009 | Miele G892SC SS Dishwasher
Bosch shu5304uc/u06 does not drain
sounds like the pump has something in it or the drain line is clogged or kinked some how
Jun 07, 2009 | GE Nautilus 24" Built-in Dishwasher
Water does not drain after the wash/rinse/and dry cycle
You don't list the make and model of the dishwasher, but generally,when an older dishwasher is not fully draining and the remaining water is not clean, the wash pump motor is failing.
But first check the drain hose from the base of the dishwasher clear to the drain. Make sure the hose is not obstructed. If that hose connects to a disposal, check closely the drain pipe on the disposal.
Good Luck!
May 05, 2009 | Dishwashers
My whirlpool dishasher model wec25002 will not drain all of it's water. how can you check the drain?
first check under sink where drain water goes out,,take drain hose off and see if your clogged,,keep me post onthejob,,i will walk you through...warning care dishwashers are not ground,,
Jan 18, 2009 | Dishwashers
Dishwasher full of water at end of cycle
OK,,,,,,,,,,,seems to be the pump impellars or either clogged with grease ect. Find the pump amd remove the cover to it that you can have access to the inner impellar. I have seen this problem before and found that this was the problem , I hope this is yours. Goood luck RC
Oct 13, 2008 | Miele G880 Dishwasher
No drainage
You have an obstruction in either your rubber drain hose running from the machine to the drain pipe, or in your actual pipe itself. Make sure the hose has no kinks in it or hard turns to obstruct the flow of drain water when the machine is trying to drain it out. Good luck!
Jan 27, 2007 | Sears 24 in. 14181 Built-in Dishwasher
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
384 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
