Question about Proscan PS32600 32" TV
Proscan ps32600 Tv only clicks 3-4 times when power buttn is pressed. will not turn on.
PRESS AND HOLD THE POWER BUTTON UNTILL THE LIGHT CHANGES AND TV WILL COME ON
Posted on Mar 04, 2009
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
Inoperable
i got tv konka k1418c3 some bodyelse repaired was not good every thing was gone like v 402 and anoter elco was gone so i need scematic diagram thanks alot
Feb 06, 2014 | Proscan PS32600 32" TV
Power cycles on and off
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Jan 01, 2014 | Proscan PS32600 32" TV
How to hook up a dvd on a proscan ps32600 tv
This tv has 2 AV inputs at rear to connect dvd player or any other video source.
Plug RCA video cable in AV Input-1 at rear of tv and select Input-1 source in tv remote to get dvd player playback picture in tv.
Click HERE to download user manual free copy that has details about tv operations.
Hope these info will help you.
Thanks.
Nov 26, 2010 | Proscan PS32600 32" TV
TV cycles off and on and then stays off, you can hear it clicking off and on
check it on your technician.theres spareparts inside deffective..ro go to service center
Sep 07, 2010 | Proscan PS32600 32" TV
The screen turns on hen off
Just try to reset;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Sep 14, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan lcdtv/hd model L19LA25Q
Pull up each preset and adjust to your liking for that particular setting. Go to the next one and do the same. If this is not possible, overall brightness needs to be brought up from the service procedures...accordianman
Nov 04, 2007 | Proscan PS32600 32" TV
Proscan 27" tv
it is due to power supply failure. 1 check for loose contact in power supply. 2 it might be due to plug or socket loose. 3 switching circuit failure in power supply. good luck.
Oct 07, 2007 | Proscan PS27500 27" TV
My tv wont turn on all it dose is beep when i pluge it in
If you look on the back of the set, there will be a chasis # probably a CTC169 . These sets usually need to have the power supply repaired. These are great sets and have an awesome picture. There is a kit,I which is available to service technicians which will repair the power supply in most cases. If you can find a good local technician , they should be able to repair this problem for approx $125-150. if you have further questions pertaining to this set , I will be happy to advise you. I probably have repaired a coule hundred of these sets. This is one of the few old crt sets that are worth fixing. Scrivitron
Jun 24, 2007 | Proscan PS32600 32" TV
Proscan TV Instruction Need
you wont be able to the high with rabbit ears antenna you will catch the low free channel.you need the cable to get the high channel.so it is est to connect back your cable good luck
May 06, 2007 | Proscan PS32600 32" TV
Proscan PS32600 32" TV Logo
189 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
