52 inch bravia will not turn on. Power LED goes to Standby LED and "blinks" three times.
  • Anonymous Mar 17, 2014
    I have a 97 Rca 52 inch and when i go to turn it on the green like tries to come on three times but the picture doesnt come on then the green light stops
  • 11,896 Answers
Firstly, Unplug tv for at least 4 hours. Better yet overnight. This is what we call a Hard or Master Reset.
This should solve your problem. If it doesn't it may be that the set has a bad transformer (high voltage)
Posted on Jan 17, 2009
My sony 52" TV XBR9 won't turn on and shows 6 blinking lights on the led indicatior. What circuit board should I replace first?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 23, 2015 | Sony Bravia Kdl52xbr9 52 1080p Lcd Tv...
42 inch BRAVIA turns off and I get 2 "blinks" from the Standby LED
Aug 28, 2014 | Televison & Video
My standby light blinks three times but tv never comes on
These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/.If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 22, 2013 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My bravia kdl52nx800 shuts down right after turning it on. flashing 6 times
Very common problem the 6 blinks is indicating an issue with the Inverter. Replacing the inverter should solve the issue. You should be able to get the Inverter from www.tvcircuitboards.com
Oct 27, 2012 | Sony KDL52NX800 52 inch BRAVIA 1080p LED...
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a 52 inch sony bravia. turn it on and i hear a buzzing sound then the red standby light blinks 13 times.....what gives. I need help
Sounds like the lamp is blown. Check your manual to see what the blinking lights mean and how to check the lamp.
Jan 16, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
May 14, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
52 inch BRAVIA turns off and I get 3 "blinks" from the Standby LED
Firstly, unplug your television for at least 4 hours. Even better overnight. This is what we call a master or hard reset. It will hopefully fix your problem The tv may be in safety mode for some reason.
If this doesn't work it may be the set has a bad transformer (high voltage)
Jan 17, 2009 | Televison & Video
Televison & Video Logo
482 people viewed this question
Top Televison & Video Experts
Electro Med Services...
