Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Memory storage falty
When I bought the verbatim Store 'n' Go USB Device 1 GB. it was devided into two sections (Private sone and general sone )and a password was required to enter. Now the password entry dissapeared and I have only 192 MB availlable. At a cost of about 80 Dollars it is a waste. Can it be fixed. Please help. Thank You Gabriel
  • 1 more comment
  • Gabriel Henning
    Gabriel Henning Jun 23, 2007
    Let me explain... I Know very little about computers. It will be better if you take it easy with me..(70 y.o) I just bought this device to store all my photos and be able to enjoy them on the TV. Under properties of this device it allows for formatting...Is this what you mean.
    Under Properties
    Format Public zone (F:)
    Capacity 193 MB
    File System Fat32
    Allocation Unit size Default allocation size
    Volume Label Public zone
    Format options
    Quick format
    Enable compression
    Create a MS-Dos start up disk.
    When I used the device the first time It required a password to open the private secion and you had the choice to enlarge or decrease the memory of either of the two sections. I stored some sensitive material on the private section and it is now assumed lost.
    THanks
    Gabriel
  • Gabriel Henning
    You must please take it easy with me (70Y.o) I dont now much about computers.
    Wjhen I bought this device it hat a private and general zone and the memory allocation to both section could be reduced or increased. The Private section had to be opened by means of a password only... Now all is gone no password or the rest of tjhe memory space.
    Under properties of the UBS device it states.
    Format Publiczobe (F:)
    Capacity 193MB
    File System Fat32
    Volume label Publiczone
    Format Options
    Quick format
    Enable compression
  • Gabriel Henning
    Gabriel Henning Jul 07, 2007
    My problem is still there...I supposew I will have to write off the money I paid to getit fixed. I need to be guided through the process of down loading software to fix it. What to download and how to use it. There is quite a number of downloads. I could have it looked at locally, but I am not sure how much is left on the section That I cannot use. That info should not be available to anyone. That is why I decided to use your offer. If it could not be fixed, I will have to destroy it completely and buy a new one. I am in the private detective business.(Divorce only)
    Novelist:
  • 135 Answers
I agree with Noggin. This device can most likely be made useable for you again, but we would have to know exactly which device it is to give you the advice you need. This includes: - model number - serial number - color of the device We could write a detailed description to instruct you on how to download and implement the correct software that will restore your device to useability, but the software is very specific regarding these details - which is why we need to know these things before writing instructions on how to repair it.
Posted on Aug 06, 2007
  • 944 Answers
You should be able to format the drive using the appropriate software - if you don't have it you should be able to download it from this link; http://www.verbatim.com/support/downloads.cfm If it doesn't let you format it back to the original configuration then there could well be a more serious problem - let me know what results you get and exactly which type of drive you have and i can hopefully help if you have no luck with formatting. Good luck :)
Posted on Jun 23, 2007
  • Anonymous Jun 23, 2007
    Try formatting the public zone from the properties as you have seen - try a quick format first, then check and you may find the private zone / password is back.
    If not then if you look again, the publiczone is labelled F: - check through the list again and you should have listed A: which is your floppy disc drive, C: which is your computer hard drive D: and E: may be extra hard drives if you have more than one or they would more usually be CD or DVD drives.
    F: is the publiczone part of your USB drive, it may be that the private zone is labelled similarly, but as G: or H: etc. if so, try to open it and it should prompt you for the password, properties should also give you the same options as for the public zone, but it will at some point in the process need the password to continue.
    Think of your USB drive as two separate drives that have no real connection to eachother if that makes it easier to understand.
    I need to know exactly which drive you have to give any more detail, there are several different 1Gb store 'n' go models.
    Also would be useful to know which operating system you are using - I am guessing windows - please tell me which version.
  • Anonymous Jul 12, 2007
    In order to talk you through the steps required to download the necessary software to tyr and fix your problem, I need to know from you which computer operating system you are using. It may be windows XP, windows Vista, windows 2000, windows ME, windows 98, windows 95, windows 3.11, Mac OS?, or several more. If you are unsure of this detail then just watch your computer as it is starting up, somewhere in the initial screens it should tell you.
    The reason why I couldn't be specific about which software you need to download exactly, is that there are several different versions of the Verbatim "Store n Go" 1Gb. If you are unsure exactly which version you have, then look very carefully for any serial numbers, or any instructional paperwork that came with the storage device.
    If you let me know this information then I can hopefully help.
    Please do not give up until you have tried to fix the problem by giving us the required information.
SOURCE:
Verbatim usb drive 8 gb help
I would like to give you some solution steps. However you haven't indicate your Operating System. So please let me know the operating system (XP, Vista etc)
Feb 04, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
How can i send pictures from windows photo gallery to verbatim?
When you connect the SmartDisk into the USB port of your computer, the computer will detect this as an external storage device. When you open this SmartDisk you can create folders to store your photos. Just select your photos from your computer where the photos are stored then copy and paste these photos into the folders on the SmastDisk.
Sep 25, 2010 | Verbatim SmartDisk Firelite Portable USB...
I have a 1 GB Verbatim and deleted password login
Hi unfortunaltey there isnt much you can do
There are some free data recovery software out there which you could try
the only way around this is to format the drive, do this by clicking on my computer, then right clicking on the USB flash drive and clicking format
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
5.84 GB will not fit on the 8GB Store N Go
Easy Fix.. You need to reformat your USB File System to NTFS rather than FAT32 (Default). FAT32 limits the size of all downloads to 4 GB. NTFS has no upper limit so you could download an 8GB file, if you wanted..... FAT32 is the default on the unit you have. Easy fix.... right click on your drive, click 'format', 'file system' change to NTFS and click 'start'. That's it ! ! ! !
Nov 19, 2009 | Verbatim Electronics - Others
Verbatim 8G USB memory storage stick not working
There could errors in the drive. You should either run a scandisk on it or format it altogether. Either should get it back up and running is it is a genuine device.
1. To check for errors/scandisk right click on the icon of the memory stick, select properties. Under the properties menu look for Error-checking and select check now. The check disk menu pops up. See that Automatically fix file system error box is checked. Then click on start.
2. If you decide to format the memory stick just right click on its icon and select format. But see that you move you vital files from it first else you will loose them.
Sep 04, 2009 | Verbatim VER95327 USB Hard Drive
Verbatim thumb drive
Im not specifically sure what to do, but I would try reloading the Store 'n' Go application and see if it helps.... You can download it here....
http://www.verbatim.com/support/support.cfm?open=Articles
If not, try contacting Verbatim and see what they say about it. After all, it is their product... if anyone knows how to fix it they should.
Their contact info is:
Phone Support
For Technical Support
Mon - Fri 8am to 9pm (EST)
1-800-538-8589
Online Support
http://www.verbatim.com/contact-login.cfm
Hope this helps.......
Jul 31, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
USB Drive no longer responding
Ok,
So it wasn't obvious damage then lets do the next step, Right-Click on My Computer, then select Manage, when the MMC opens select Device Manager on the left side, Open USB Devices and look for USB mass Storage controller. If it is not there then it's likely the controller board in the Verbatim shell is dead.
If that is the case, your best bet will be to drop by a local computer store and purchase an empty HDD enclosure to move the drive into.
If it does show up as a USB mass storage controller but not as a drive the problem is more likely in the circuitry of the HDD itself and you may require the assistance of a data recovery pro.
Chris
May 26, 2009 | Verbatim USB 2.0 HD DRIVE 12GB STORENGO 12...
Bought a Verbatim 1Gb USB Drive with some .pdf files for secure zone. I overwrote these accidentally.
usb drives dont have manuals the computer automatically detect the drive.
in saving files it is the same when you save in a floppy or other drives.
Jan 31, 2008 | Verbatim VER95327 USB Hard Drive
Microsoft Windows 2000 help Processor:, Intel Pentium 133 MHz or equivalent 8 CPUs Supported. Memory:, 256 MB. Drives:, 1.0 GB Disk space CD-ROM / DVD drive ...
Computer questions and answers listing 200 - 299 CH000273, Not able to see over 8.4GB hard drive. CH000274, Not able to see or boot with hard drive over 33.8GB. CH000275, Unable to see over 8GB with ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
78 people viewed this question
Top Verbatim Computers & Internet Experts
gggg
Don Hart
Duncan Mutch
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
