Question about Car Audio & Video
How can i remove the stock cd player from my 2002 ford escape?
  • 4 Answers
1. Get it professionally done at your local best buy. 2. op it out wit a flat head screw driver and disconnect the wires in the back.
Posted on Jan 20, 2009
CD eject error
My wife has a 2002 Escape and has a similar issue. She uses a piece of cardboard and slides into the CD slot and slightly presses the CD. In turn, the mechanism pushes the CD out.
I have had the CD player out in it's entirety, and nothing appears to be wrong.
Hope this helps.
Jun 11, 2010 | 2002 Ford Escape
My 2002 ford escape in dash cd player gives me an error when i try to ejeck my cd's
You can take the unit to the dealer order an exchange unit. When you send in your old unit they will return the CDs. If it has a CD error they are not going to come out unless the unit is dismantled.
Jun 01, 2010 | 2002 Ford Escape
I have a 6 CD player in my escape that has worked just fine for six years. last week when I tried to play a CD, it said CD error. When I tried to eject any of the CD's, it said no CDs loaded. How do I...
Sometimes things just quit working. Not many parts on a car last a lifetime anymore. Chances are your stock radio has gone bad and it would'nt be worth while to have it fixed. Go to a ruputable audio place( best buy, circuit city) have an aftermarket radio/cd player installed, this would be the cheapest fix for your problem.
Feb 16, 2010 | 2003 Ford Escape
My 6 cd player in my 2002 ford escape wont play any cd's or eject any of the 5 I have in the player. What can I do to fix it?
ITS DONE WITH ..TAKE IT OUT AND PUT IN AFTERMARKET UNIT..VERY EXPENSIVE TO REPLACE FACTORY UNIT...
Oct 26, 2009 | 2002 Ford Escape
2002 Ford Escape, cd's stuck in 6 CD player..how do you fix that and how do you remove faceplate
i had the same problem. the slots inside the cd player that hold the cds slide up and down according to which one you pick. a couple of those got stuck on mine. i took it apart and got the cd out, but wasn't acutally able to fix it. some of the gears got stripped because i waited to long to fix it and it just ground the teeth down trying to get it to work. you can pick up ford radio removal tools at wal mart, or any car audio store to pull your radio out.
Oct 22, 2009 | 2001 Ford Escape
Removal of rear brake drum 2002 ford escape
make sure handbrake is off take wheel off hit the drum with a mallet not steel,as it will brake,hit on outter diametter face of drum, try and rotate as you twist off
Jan 05, 2009 | 2002 Ford Escape
6 CD Changer/Radio on 2002 Ford Escape
Check this, it worked for me
http://www.i-hacked.com/content/view/213/45/
Oct 14, 2008 | 2002 Ford Escape
Need the audio wiring diagram to connect premium cd player
i need to know if my 2002 ford ranger standard cab truck has a cd connection on the stock radio
Aug 02, 2008 | 2002 Ford Ranger Regular Cab
There is a CD jammed in the cd player. (6 cd changer) It is a 2004 Ford Escape
It happens to me all the time on my 2002. Try cycling the load and unload buttons for the stuck CD location. If that doesn't work try ejecting the CD. When the slot door opens, try putting another CD into the slot and push on the edge of the stuck CD.
Jul 27, 2008 | 2002 Ford Escape
STUCK CD
you will have to remove and open the changer, and remove cd that way, hope this helps
Jun 22, 2008 | 2002 Ford Escape
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
