Question about LG WM-2277HW Front Load Washer
TROMM WASHER WM2277HW LG. GET IE ERROR AT BEGINNING OF WASH CYCLE
CLEANED INLET FILTERS.CHECK FAUCETS YET NO WATER ENTERS TUB. MACHINE AT CONTROL PANEL HAS A SLIGHT HUMMING NOISE I DO NOT REMEMBER HEARING BEFORE.
  • Dan Unknown Jan 17, 2009
    I have the exact same problem with model WM2377CS from LG. I took off the top, put the machine into test mode, and both the hot water, and the cold water inlet valves buzz, with no water entering the tub. Is it possible that both valves let go at the same time?
  • Anonymous Apr 20, 2009
    I have the same problem mine will stop in the middle of the cycle and start beeping and it will have a ie error on it. How can i solve this problem.
  • 5 Answers
That noise means it is blocked. Did you get the filters in the back of the machine at the inlets? I've been through heck with this.... check out what finally worked.
IE= Inlet Error. I have struggled with this problem. After much trial and error it appears that it is due to my well water. People who have city water will probably not have this problem with this machine. Well water or hard water buyers beware. This machine is VERY much a primadonna princess capable of stopping your rinse cycle at the slightest imperfections. This is the Princess and the Pea of Washers... but I have a series of possible solutions that will have you appreciating her primadonna superiority once again.
Troubleshooting... Listen.... Does she sound like she is struggling and no water is coming in? If so then it isn't. The cycles will last forever as she makes all sorts of grunting noises. Something is preventing the water from coming in. It could also be that the pressure in to the washer is under 55 psi.
a. I have adjusted the pressure in the pumphouse to allow for minor fluctuations so that the machine will have at least 55 psi.
b. Take off the hot and cold inlet hose and clean the screen at the back of the washer. The two screens are supposed to come out of the male receptacles. They are fragile... beware. I use a squirt bottle/atomizer to clean these screens as mine chipped and will not budge.
c. You can add a screen just off the faucets so that you don't have to move the machine each and every time you get an IE error. This helps but does not solve.
d. I installed a faucet filter that I bought from Home Depot in the PVC sprinkler's section. They are made of a black plastic material and can easily cross thread, so be careful. They look about the size of a one liter container and unscrew midway to reveal a removable cylindrical mesh filter. This makes it possible to widen the surface area where tiny particles can be trapped without totally blocking flow to the inlet sensor. :-) When installing this make sure to completely rinse the hoses, and all screens coming into the machine. I took the shortcut first and thought my idea had failed only to discover that the screen behind the washer was partially blocked.
e. Periodically remove the filter and clean. Depending on the quality of your water, you may need to do this at all the points that have a screen.
I now have a screen washer between the sprinkler system filter and hose and the one that comes installed inside the male ends of the inlets for the water hoses. This has helped enormously.
f. Another possible offender is the soap and softener dispenser. To remove and clean press down on the plastic toggle piece on the soap side, the whole drawer should slide off and clean. Non-HE detergents and softeners can create a buildup of gooey gunk. Just clean it. Inside the drawer space you can clean to increase flow. I use baby wipes.
g. Make sure that the filter on the bottom is free from obstructions. If there is water in the drum, you will be flooded if you remove. This is a last resort after all the inlet lines have been cleaned and cleared.
Note: It doesn't take much to lower the flow of water to the point that this machine will not run. Since you cannot override the computer on it to run a spin cycle or even advance to remove water it can be highly frustrating. I've learned to obey my machine and just clear every last possible inlet.
Best of luck.
Posted on May 30, 2010
  • 332 Answers
Your fill vlave is not working,,, turn off the water supply and remove the clamps and undo the wires, could be just a plug in, may have to cut the wires get you a new one reinstall it with the flow going in the right direction and you will have water!!!!
Posted on Jun 23, 2009
ERROR CODE 1e
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
You may try the following link, too http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
Sep 19, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
My fuzzy logic LG washing machine, is no longer spinning or washing the clothes its showing error
Check another faucet in the house to make sure your household water pressure is adequate.
Reference:
May 19, 2015 | LG Washing Machines
Lg tromm washer what does IE stand for?wash machine stops running and IE appears
LG's 'IE' stands for (water) 'Inlet Error'.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 04, 2011 | LG WM2688HWM TROMM SteamWasher
My LG WM2277HW washer always gets an IE error. To finish the wash, I change the setting to Speed Wash and punch Rinse Spin. Sometimes, I get lucky and the wash finishes. Most of the time, I get another...
Hi
Thanks for using FixYa. Error IE water inlet error which occurs when correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. To start with you can try to clean the filter if this wont help then you'll have to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | LG WM-2277HW Front Load Washer
Not completing cycle error IE
IE is a water supply error. turn water off to machine and unscrew your 2 water hoses on back of machine and clean inlet screens with old toothbrush. if they are clean, you probably have a stuck closed water solenoid.
Jul 25, 2010 | LG WM2277H Front Load Washer
IE error code
The "IE" code indicates a water inlet problem. If the correct water level is not reached in eight minutes, this code is generated. Check the water inlet valve. Unplug the machine, turn off the water, and remove the water supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter.Check for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will have to be replaced. I'll attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 24, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Jul 17, 2009 | LG WM-2277HW Front Load Washer
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,384 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
