Question about NetGear WGR614 Wireless Router
WGR614v5 will not configure - NetGear WGR614 Wireless Router
  • ag_ghost May 11, 2010
    What will it not configure?
    Assuming the lights indicate it's working, can you tell if it has assigned your wired or wirelss interface on your PC an IP address? If so, it will usually start with 192.168. If your IP address starts with 169, your PC and the router aren't communicating.
    Often, it's easier to configure at first via a "hardwired" LAN cable from your PC to one of the four jacks in the back of the router. The jack to connect to a cable or DSL modem is slighly offset from the other 4.
    The default login for WGR614v5 routers is http://192.168.0.1 (i.e, entered as a "web address" from an internet browser. If, after typing that "web address" in, it doesn't ask you for a login name and password, then that router probably hasn't been able to assign an IP address to your PC.
    Genius:
  • 1,124 Answers
I have tried every possible way to rest my netgear wgr614v5 router and the log in page will not come up. Is there any other way I can get my router to send out signals so it can be picked up bu other...
The best way to do it, though you may have tried it already, is to use a pen/pencil and push the reset button in for 5-10 seconds.
This will usually reset it to the factory default settings and reset any password protection on its wireless.
If not, it's a problem with the other computers detecting the signal, be it not in range or something else.
Mar 13, 2011 | NetGear WGR614 Wireless Router
I have a netgear WNR1000 and my xbox live doesnt work
Using Xbox Live with NETGEAR Routers Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); NETGEAR has Xbox certified routers!
Note that the listed, certified firmware may no longer be available; later firmware is likely to work, but is not certified unless listed.
There is no information on what will be certified in the future. But if an existing model does not appear on the product dropdown on NETGEAR Home Page, then it will not be certified.
Nov 11, 2010 | NetGear WNR1000 Router
Win7 driver for wgr61v54
If it is not on the windows 7 compatability list ... you probably will not find a driver ...
Please dont kill the messenger ...
http://www.microsoft.com/whdc/hcl/default.mspx
If this is the case ... it may be time to replace your 'legacy' hardware.
May 01, 2010 | NetGear WGR614 Wireless Router
We transferred to a new home and a new dsl account. I've reset my netgear wgr614v5 to its default settings and reconfigured it to access but now it only works for pc's that are wired into the ports....
When you reset the router the default setting for encryption is probably off. Hopefully you had encryption on in the old home - but now the wireless computers are still trying to connect using the key/encryption.
Feb 05, 2010 | NetGear WGR614 Wireless Router
Is Netgear Route WGR614V5 compatible with Windows 7?
Please note that this router is compatible with Windows 7. Please perform the below steps on your Windows 7 computer to connect to the wireless network:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear WGR614 Wireless Router
Test LED is continously ON, I cannot ping the IP
1)If the test light is ON , it means the system is initializing or in the middle of a firmware upgrade and so the ping test will not be successful.
2)If the firmware has not been upgraded then power cycle the router for a min and check which means take the power cable out for a min and then plug it back and if the light status is still the same then go for the soft reset.
3)For soft rest get the tooth pick/paper-clip or a pin and poke it into the reset button located on the rear panel of the router and is a very small tiny circular button , wait for 30-35s and it take it out , wait for 10-15s and then repeat the step2.
4)If this does not work out go for the hard reset[but all the internet connectivity will be lost and the re-configuration has to done from the beginning]
Procedure for hard-resetting:-
a)Use the paper clip or a pin to reset the device and keep holding the reset button for at least 30-35s.
b)Then , While holding the paper clip take the power cable out from the device , wait for 10-15s and then plug the power cable back to the device while holding the paper clip.
c)Wait for another 10-15s and then release the paper clip.
d)Once we have all the lights back on to the device then take the power chord out and plug it back within 30s.
5)Check the light status if it is still the same then router is faulty and has to be replaced if not then login to http://routerlogin.net/ with username as admin and password as password and re-configure the router setting's.
Nov 17, 2009 | NetGear WGR614 Wireless Router
Connecting Netgear Wireless Router to @Wire Wireless Router
You don't need to connect your netgear, you have only to connect your computer to the 2Wire (is wireless also) - If your computer ins not wireless Only you have to do is insert a wireless PCI card in your computer or and USB wireless device and connect to the 2Wire Wireless Router
Feb 11, 2009 | 2wire HomePortal® 1800HW Router...
Wireless not working...
are u using Netgear WGR614v5? if yes, the router has to be resetted as it hangs once awhile(dunno y). By default, the wireless is "OFF"
Jun 30, 2008 | NetGear WGR614 Wireless Router
Netgear wgr614v5
Hi 632423.
We may not have enough information about it but let me set it to bits. Is it your PC / Laptop that doesnt have connection wirelessly or is it you netgearwgr614v5?
By default netgears wireless conneciviy is turned ON by default . If this doesnt work pls check admin settings by accesing 192.168.1.1on your address bar and make sure wireless is enabled . Best if reset to its default settings by pressing the reset button at the back of your router. By doin this  your router will be back to factory settings and by that the time you can check if wireless is on   {  LED light } .
Also check encryption , your wireless client installed on your PC or Windows Zero Configuration is started.
Pls let us know how we can help you more by providing us more info regarding this issue.
Good luck.
Jun 06, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
118 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
