Question about Sanyo SCP-3100 Cellular Phone
Power Problem with Sanyo-3100
I have a starnge issue with my cell phone. Red L.E.D. on the front stays on at all times. When you power down the phone it will not power back up on its own. You have to plug it into a charger to get the phone to power backup. I thought it might be a battery issue so I switch it with another known good battery. Same problem, LED stays on and You can not power back up while unplugged from charger.
  • 1 more comment
  • dat1girl Nov 13, 2007
    Yep, same thing going on here except now it won't even power up.
  • relock417 Jan 15, 2008
    I also have the same issue and no documentation exists in the users manual about what the LED light's color means. The manual states "LED Indicator shows your phone's connection status at a glance." I know flashing red means it's on mute, flashing green means a call is going through I think and possible solid green means it's on an active call. Of course, the last 2 I'm not 100% sure of because I never paid attention to the LED when the phone was working :(
  • tngras Feb 12, 2008
    I'm havng the same issue, pluged it in to charge & now it won't power up.
    Problem Solver:
  • 14 Answers
About the only hope of repair I can see is to clean the charging/data connector with 99.9% rubbing alcohol and dry the phone out gently for a while with warm dry moving air, that might work if your very lucky. Best of luck!
Posted on Mar 03, 2008
SOURCE:
Where is the sim card located for the sanyo scp-3100 phone?
Sanyo SCP-3100 is a CDMA phone so it doesn't have a place for SIM card.
Mar 01, 2011 | Sanyo SCP-3100 Cellular Phone
What is the MSL Code
Get the Unlock code for the SANYO SCP 3100 model mobile at
http://www.superunlockcodes.com/sanyo-scp-3100/rs12wp9/ and Unlock it from the Network lock.
Nov 10, 2010 | Sanyo SCP-3100 Cellular Phone
Where can I find the Free software to download pics for my Sanyo SCP-3100
try www.getjar.com find a application you want and get the quick download code.. then use your devices browser got to .getjar.com.and enter the code on the mobile site , this will down load it directly to the mobile device. if your device is not supported then select from generic j2me applications .
Oct 29, 2009 | Sanyo SCP-3100 Cellular Phone
Forgot lock code for my Sanyo 3100 by Sprint
I thank you the good word you done in the telephony system i want you to send to me the sanyo 3100 esn.exe
Nov 24, 2008 | Sanyo SCP-3100 Cellular Phone
Sanyo 3100 error
call *2 and check if u have the picture message plan if yes you must reprogram your phone again
Feb 03, 2008 | Sanyo SCP-3100 Cellular Phone
My sanyo 3100 wont find service
What they are telling you to do is, reprogram your phone, to do this they have given you the SPC code. Dial ##726100# and a menu should appear, the select edit, enter your ten digit wireless number, press ok, then enter it again and press ok, select save and or exit/reset to complete the process. Your phone should power cycle, thus after a restart the unit should no longer read [Service Required] on the other hand if that does not work for you please reply to this suggestion and request my email address and I will arrange with you to have your unit repaired as I repair Sanyo phones myself. Good luck!
Oct 28, 2007 | Sanyo SCP-3100 Cellular Phone
Sanyo SCP 3200
Remove the battery and the plastic sheet on the screens (if still on them). Put phone in the oven turned to lowest setting (below 200 F. if possible). Let stay in oven for 8 hours and try the phone. This procedure fixed mine after it was in washing machine.
Sep 04, 2007 | Sanyo SCP-3100 Cellular Phone
Sanyo SCP-3100 Cellular Phone Logo
82 people viewed this question
Top Sanyo Cell Phones Experts
Ekse
Steve Allison
Steve Allison
Wess Rohadfox
Wess Rohadfox
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
