Question about GE Advantium 120 Convection/Microwave Oven
MY ADVANTIUM EVERYTHING WORKS BUT THE MICROWAVE.
ALL LIGHTS WORK. WHEN I DIAL MICROWAVE, THE PLATE SPINS AROUND BUT THERE IS NO COOKING GOING ON.
  • 2 more comments
  • LBPulling1 Jan 19, 2009
    Everything works but there's no heat in either microwave or quick cook.
  • hubba002 Feb 01, 2009
    I have the same problem. Everyting works on our 1 1/2 yr old Advantium 120 but the microwave. Anyone have ideas as to what could be wrong?
  • IQ-Home Feb 02, 2009
    Yep, ours is just over a year old; wouldn't you know it.  The lights  adn fan work, but nothing else; won't cook.  This was a new home installation wiht two GE trash compactors too.  One of those just stopped working too.
    I guess I'll stick with Kenmore from now on!  GE is definitely OFF the list!
  • mills3509 Mar 25, 2009
    I have the same problem, mine is 6 years old. Its been a great oven till now.....
  • GE Master
  • 9,086 Answers
Sorry our chat session got cut off. It's so quirky...
Feel free to e-mail me at prototech@usa.net but the link to the manual is here:
http://www.microwavedisplay.com/sca2000_sca2001_install_sm.pdf
Posted on Jan 17, 2009
  • William Miller
    William Miller Jan 26, 2009
    Do you have an update for us?
    Did you diagnose your problem?
GE Advantium Oven stopped working
Could be an open internal fuse, magnetron, or control board failure
Aug 29, 2017 | GE Microwave Ovens
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Problem with the GE Advantium (model sca1001fss01) Convection / Microwave Oven Everything works except the microwave. It makes a sound like its working, table turns, but does not heat or cook.
sounds like the magnetron. Youll have to have a technician replace it. if you have a warranty just call the company and they should take care of you.
Jan 29, 2011 | GE Advantium 120 Convection/Microwave Oven
Re: "my GE Advantium SCA2001
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 31, 2010 | GE Advantium 120 Convection/Microwave Oven
My GE Advantium Microwave first had the cook top light go out. I replaced the bulb and it worked for about a week. The control panel went haywire, and then the interior light went out. I have replaced...
In this case, you have to check the control panel. There might be wire connections and contacts that loosens. The bulbs inside the oven is connected to a switch that that only functions once the oven is in closed position.
Nov 05, 2010 | GE Advantium SCA1001SS Convection /...
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
GE dvantium microwave stopped heating cookies on the 30 sec cycle
I have arranged for a GE technician to visit my home this Thursday.
Thanks for the e-mail
Sep 02, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
204 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
