52 inch BRAVIA turns off and I get 3 "blinks" from the Standby LED
  • jambojammy Feb 23, 2009
    Ok Now Let's Fix Your Bravia
    First Unplug It From the wall Wait 5 min
    2.Open The Screws with the arrows pointing on them
    3.The cover should Come Off (DON'T PUT YOUR FINGER ANYWHERE until told)
    4.There should be 3 separate boards one of them will be green
    5.The Electricity Board Should Have Many Wires
    6.unplug all of them
    7.Switch your tv on (watch for Shock)
    8.Wait for 10 seconds and switch of at the wall
    9.Plug all wires back in except for smallest one
    10 Then Switch on again It should Come on Green Then turn red.
    11.Unplug one more time and plug the final small wire in
    12.Screw back Panel Back in and Switch On tv Should Come On
    13.With a setup menu like when it was new thanks!
  • 11,896 Answers
Firstly, unplug your television for at least 4 hours. Even better overnight. This is what we call a master or hard reset. It will hopefully fix your problem The tv may be in safety mode for some reason.
If this doesn't work it may be the set has a bad transformer (high voltage)
Posted on Jan 17, 2009
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: 52 inch bravia will not
Firstly, Unplug tv for at least 4 hours. Better yet overnight. This is what we call a Hard or Master Reset.
This should solve your problem. If it doesn't it may be that the set has a bad transformer (high voltage)
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
My sony 52" TV XBR9 won't turn on and shows 6 blinking lights on the led indicatior. What circuit board should I replace first?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 23, 2015 | Sony Bravia Kdl52xbr9 52 1080p Lcd Tv...
What would be the cause? Sony Bravia standby light 3 blinks times any ideas?
try re-closing your lamp door. indicates possible lamp door/switch problem
Jul 19, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
What is the cause bravia 3 blinks?
Power supply has a voltage spike caused by damaged capacitors.
KDL-52w4100 won't turn on and LED blinks 6 times
Bus clock and/or data lines low at power on. 6 blinks of standby light denotes this. Actually, it should be a motherboard problem. Your TV need a thorough checkup before confirmation. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My bravia kdl52nx800 shuts down right after turning it on. flashing 6 times
Very common problem the 6 blinks is indicating an issue with the Inverter. Replacing the inverter should solve the issue. You should be able to get the Inverter from www.tvcircuitboards.com
Oct 27, 2012 | Sony KDL52NX800 52 inch BRAVIA 1080p LED...
Tv turns on then turns off and the standby led starts blinking
Standby light blinking is sign or internal problem in tv and how many times it blinks is error code that will show what section of tv got problem. Count light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 13, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a 52 inch sony bravia. turn it on and i hear a buzzing sound then the red standby light blinks 13 times.....what gives. I need help
Sounds like the lamp is blown. Check your manual to see what the blinking lights mean and how to check the lamp.
Jan 16, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
52 inch bravia will not turn on. Power LED goes to Standby LED and "blinks" three times.
Jan 17, 2009 | Televison & Video
Televison & Video Logo
1,268 people viewed this question
Top Televison & Video Experts
Electro Med Services...
