Question about Hoover H160E Front Load Washer
Hover Washer H160
After a complete cycle washer does not stop but continues to from the start again
    Sergeant:
  • 236 Answers
Sounds like the timer may be faulty.
Posted on Jun 23, 2007
SOURCE:
Why is my Roper washer continuously running?
Could be a defective controller (there goes that $150)
Jan 18, 2016 | Roper Washing Machines
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
I have the Kenmore front load washer HE2. How do I use the clean washer cycle.
Hello, welcome to FixYa.
In order to perform a "clean" on the HE2 is as follows...Read these instructions completely before beginning the cleaning process.
**If necessary, the cleaning cycle may be interrupted by pressing STOP. This will stop the cycle. A RINSE/SPIN cycle must then be run to thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage to the unit and clothing added to the next cycle.**
Begin procedure
1) Open the washer door and remove any clothing or items from the washer.
2) Be sure the door is closed.
3) Open the dispenser drawer and immediately add 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to this cycle. Use of more than 2/3 cup (160 mL) of bleach will cause product damage over time.
4) Be sure dispenser drawer is closed.
5) Select the CLEAN WASHER cycle.
6) Press START.
NOTE: The basket will rotate, then the door will unlock, lock again, and then the cycle will continue. The machine will not fill, but the basket will rotate while the washer runs a short sensing cycle. This will take approximately 3 minutes.
7) The cycle will determine if clothing or other items are in the washer. a) If no items are detected in the washer, it will proceed to step 8. b) If any items are detected in the washer, all cycle lights will flash and "rL" or "F/34" will be displayed. Associated LED status lights will remain lit. The door will then unlock. Press STOP to cancel the failure code. Then repeat steps 1, 2 and 6 to start the cycle again.
8) Once the cycle has begun, allow the cycle to be completed.
9) After the cycle is complete, leave the door open, slightly, to allow for better ventilation and drying of washer interior.
Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
Calypso washer is not completeing "normal" was cycle
could be or you may have a problem with the lid switch ( Ld )
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
Hoover H160E Front Load Washer Logo
292 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
