Question about Nikon FG 35mm SLR Camera
LED not showing
I've replaced all the batteries, but the LED lights aren't working in any mode. Any suggestions? Camera finally died??
  • Anonymous Feb 05, 2009
    i just started using mine again too and of course the LED isnt working even with the new batteries i put in it.
    Scholar:
  • 58 Answers
Check the battery contacts. If the camera has not been used for some time then corrosion and dirt can prevent a good contact being made.
Posted on Feb 05, 2009
Flash doesn't work. Flash icon shows on screen but doesn't fire.
It is detecting it has enough light and not flashing. Look for an "indoor" or other appropriate mode for what you are shooting since most Samsung cameras have them. The flash will only go off when the camera thinks it is needed. Canon Cameras are useless indoors but Samsung's are pretty good indoors when you find the right setting. Their latest models have dozens of modes, most of which you will never use. They are just VERY slow to take pictures. It appears to be cheaper version of their WB250F I had for a while.
P.S. - Never drop a Sansung camera. They will chip and even get damaged from as little as a foot or so. I had one fall about a foot onto pavement and it was permanently ruined. Their older models also stop with lens out when the battery dies but the Galaxy Cam is finally smart enough to retract the lens before the battery dies. It alos does so when shutting down unlike the older models.
Apr 16, 2015 | Samsung ST-200 16 Megapixel Digital Camera...
Why suddenly my remote control cannot Control tv . It can before , but now cannot
Check to see if the infrared led is working. Here's how to test, using your cell phone camera, point remote to the camera (cell camera must be on) then press any button in remote, on the cell phone camera, you will view a white light, if no white light comes on while you pressing the remote buttons, then the infrared led has died our, needs to be replaced. Alternatively check batteries are OK, make sure there is contact with connectors inside battery bay
Nov 12, 2014 | Televison & Video
Logik L32LCD11 remote not working!
use this simple test see the video.the led coming with the r.control must be light to the digital camera. If the LED is not lighting. Open the remote control, and clean, replace battery, and resolder any cold solder in the r. control. clean the contacts battery.
May 22, 2013 | Televison & Video
2007 is250 battery died, then was fully chared, now the car isn't detecting the key and won't start
all new cars are set up that if the battery deads it goes into lockout mode. it is so the dealer ships can make money
Dec 16, 2012 | 2007 Lexus IS 250
REMOTE IS NOT WORKING
first check the battery or replace with new one. if the batteries are ok try to check the transmitter of your remote ( IR led) . you can check it by focusing camera or cellphone camera into the IR led of your remote then press any button on the remote if bright light shows your remote is working good. if no light you had to replace the IR led.marmeto12_0.jpgmarmeto12.jpg
Aug 20, 2011 | Televison & Video
I am using this camera from last 3 years. It was working fine. Suddenly, a problem occurred. Now whenever I select the Auto mode, it is set to video option instead of still image. I have formatted...
I'm have the exact same problem. Purchased the camera 3.5 years ago. Recently needed to shoot a video, when finished I set the camera back to Auto and it stayed in video. Portrait mode shows manual, all other modes work as assigned. I've noticed at least TWO other posters having the same problem within the last couple of months. It's as though this camera (mfg. 2007) has a Trojan program from the factory to make us buy newer models.
Other than resetting, is there a way to flush and reload the firmware?
May 06, 2011 | Canon PowerShot A570 IS Digital Camera
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
Red light flashes and LCD turns off and on
A quick test would be to purchase a set of Duracell Ultra Digital batteries and try them. They won?t last for very long; however, if they make the red light go away then you problem is either the batteries you are using or the charger. More often than not its going to be the batteries so we?ll start there: Check your batteries, you should be using Nickel metal hydride (Ni-ME) that are rated at 1450 (I use 2500) mAh or better. If the batteries are more than one year and you?ve used them a lot then its likely the batteries just aren?t holding a charge anymore. Purchase a new set or borrow a working set from a friend. Charge them in your charger and try in your camera, if the red LED goes away use the batteries till they need charging again. Charge them in your charger and if the red LED stays off then the batteries were the problem. If the red LED returns then try charging your batteries in someone else?s working NiME charger. Put them in your camera and if the red LED goes away then your charger is the fault.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Nikon FG 35mm SLR Camera Logo
138 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
