Question about Toshiba 32AV500U 32 in. LCD HDTV
Set up new tv
Picture does not fit entire screen
  • 4 Answers
Try using your TV remote by pressing View Source. I didn't have Toshiba but my pix did not fit screen either. I used View Source on remote and it changed how the picture filled the screen.
Posted on Jan 17, 2009
How do you adjust tv picture to fit entire screen
If you are connecting a computer to your TV and you are seeing the edges cut off it is most likely due to the zoom on your TV. First, make sure that your computer matches the resolution on the TV, then go into the TV menu and find the screen sizing setting and make sure it isn't set to stretch, zoom, etc.
Feb 07, 2016 | Televison & Video
The picture does not fit the screen
Resolution is set too high on the TV. On the TV remote open Menu
Go to set up
Change the screen resolution to the next one down.
Mar 27, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
My tv's picture does not cover the entire size of the tv. The picture that shows is the size of a square and my television is a rectangular size. How do I widen the picture?
there should be a button on your remote that adjusts the picture to fit your screen. They have that on most tv's. Are you using a cable box? your cable box also has settings depending on what your using. 1080i, 720p? does it do the same thing with a dvd player or game console hooked up?
Mar 02, 2011 | Sylvania LC370SL8 37 in. LCD Television
Picture doesn't fit on my Samsung HDTV
after searching around on both remotes for with verizon. Using my verizon remote under... settings-video settings-sd override...then into stretch mode fixes problem! Hope this helps anyone else with same problem!
Sep 21, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Screen image overlaps edges of screen and entire image is not fitting the screen
if your tv has a format button on it just press it until your picture is to where you like it. plus if you have a hd reciever it also has a format setting on it to.
May 02, 2009 | Televison & Video
I cannot get the entire picture to fit on the tv screen
unfortunately we now have four different aspect ratios, only one of which works properly on any given screen.
If you have a "picture" button on your remote, keep pressing it until the screen changes. You will have to find the correct aspect ratio in your menu settings. It is the only way to correct this
Jan 17, 2009 | Televison & Video
Picture won't fill the entire screen
Check the settings on the TV, and find an HDMI cable and connect via that, as picture quality will be far better.
Jan 22, 2018 | Sony Televison & Video
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
May 29, 2008 | Samsung Televison & Video
Toshiba 32AV500U 32 in. LCD HDTV Logo
261 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
