Question about Craftsman 8.0 amp Reciprocating Saw
Reciprocating saw problem
I have a craftsman m/n 900-275020 reciprocating saw,the piece on the front fell off ,its used to angle saw and keep pressure againgt workpiece.I think it mounts on whats called the shoe.anyway took it to sears for repair and it came back without same piece I sent it in for to be replaced..It cost 79$ and still cant be used due to missing part.I looked on the parts list and its not on there.This piece pivots depending on angle of saw on workpiece,what is it called and is it available.My saw is not 8 amp but 6.5 if that makes a difference
  • 2,176 Answers
OK just looked at the Searspartsdirect.com website and there are 2 parts that I think it could possibly be. One is the SHOE part # 399725-00 list 4.86 in stock and or guard 157325-00 list 4.59 also in stock. I would suggest that you go to this site and confirm which one you need, but the shoe is the piece that does ride against the work surface. Good Luck and let me know if I can help further
Posted on Jan 19, 2009
    New Friend:
I have the same saw. It sounds like you are talking about the shoe or the finger guard. If either of these are missing the saw will still work. My saw does not have the finger guard on it anymore. The shoe does however often ride along the work your cutting.
Posted on Aug 18, 2015
How do I replace the tool-less blade clamp in a craftsman 8 amp reciprocating saw
Craftsman Reciprocating Saw replace the tool-less blade clamp
Jun 10, 2015 | Craftsman Saws
Craftsman saw mod # 113-298051
The blade is able to be set to different angles by the handle under the front edge of the table. There is a lock handle to keep the angle set correctly. Loosen the lock handle, press a square (90 degree tool) against the flat of the blade - not the teeth - then lock the blade in place.
Craftsman 113 298051 Owner Manual rr
Jun 17, 2014 | Craftsman 10" Table Saw
How do I remove the nose piece to repair the reciprocating shaft.
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
May 12, 2010 | Craftsman 8 amp Reciprocating Saw with...
How to change the blade
look at front off saw , where blade is,there is a hex (allen) bolt, screw, or a lever on the side of saw
Apr 06, 2010 | Craftsman 8.0 amp Reciprocating Saw
How do I replace the pin?
toolpartsdirect.com has schematics plus you can order the parts there also,, but in my opinion that pin might have been part of the screw and it simply broke off
Sep 26, 2009 | Saws
Blade lock on Craftsman 10 amp recip
The guide foot comes completely out by wiggling and pulling a little harder than you would think. It is held in place by friction in addition to the two screws. Once the guide foot is removed, remove the front metal support piece by prying it out of the groove in the rubber boot. You can then access the pin and blade release lever. Make sure the return spring is in place on the rear side of the blade lock latch.
Apr 11, 2009 | Craftsman 8.0 amp Reciprocating Saw
Craftsman 8.0 amp Reciprocating Saw Logo
920 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
