Question about HP LaserJet 4600dn Color Printer
False Toner message
I have a major problem with my 4600dn. After installing a toner cartridge it goes from full to empty in the toner supplies window in a matter of a few short weeks, even though they are hardly used. I then have to bypass the empty message in the diagnostics mode, but when I have two or more "empty cartridges" I cannot bypass at all and, thus, cannot print.
    Problem Solver:
  • 5 Answers
First thing u need to use a original hp supplies. a smart chip in the toner will detect the toner level. if u r using the original toner cartridge . then probem with the toner level detecting pcb
Posted on Jan 09, 2008
  • 186 Answers
Are you using genuine HP toners? If not HP puts a chip on there cartridges that tells the machine it is a new cartridge. Some generic toners do not replace this chip therefor giving you this false message.
Posted on Jun 22, 2007
SOURCE:
Install Toner error message still displays even when replaced
If you are not using original manufacturer's replacement toner cartridges, this could be your problem, and it will not resolve. The printer and cartridge will not "talk" to each other, therefore giving you a false reading. If this is the case, you should still be able to print normally, but you will not know when you run out of ink until you actually run out, akin to a broken gas gauge in a car.
Jan 14, 2013 | Xerox Phaser Office Equipment & Supplies
After installing a new toner I have always the message to install a new one!!!
You have a bad toner cartridge or a poorly remanufactured toner cartridge. This condition called "false toner low". get original one from authorized dealer
good luck,
rate the solution
Nov 27, 2010 | Brother DCP-7040 Laser Printer
Black Toner issue
Does your toner cart have any little clear plastic windows?
HP printers shine a light through this window to ***** toner level.
Cover one of the windows with tape & the printer will think the cart is full.
Sep 03, 2009 | HP LaserJet 4600dn Color Printer
Toner level
To check the toner level, there is a little clear window on each cartridge you can use for this purpose. Hold the cartridge vertically. If you see toner in the window, it is more than half full (or less than half empty, ha!). If not, slowly tilt the cartridge toward the side with the window. Essentially, how far you tilt it before you see toner determines how far below half full it is. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option).
If you do have to replace or refill, don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, the waste toner bottle will likely be nearing capacity.
Jun 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
RESET TONER C9100
The waste toner cartridge has a transparent extrusion on the bottom, which fills with toner when the cartridge is full, but also if it is half full and shaken so that toner falls into this extrusion. If this happens, the only way to remove the toner is to open the cartridge by removing the tape, taking the two halves apart and shaking/blowing/hoovering it empty. You can stick them together again with ordinary sellotape.
Jun 17, 2009 | Epson Aculaser C1100 Printer
Waste toner full/empty message
this messages referes to the waste toner being full or not installed.
Manufactures try to stop you from emptying the container by having a small "window" that the printer looks through, when you empty the toner there will still be some toner on this window, so the printer will still believe that it is full.
a way around this is to wash the container out with water (do not use hot water as this will melt the toner). i also wouldn't recommend pouring the water & toner down the sink as this could be breaking local laws.
Dec 18, 2008 | Samsung CLP-500N Laser Printer
Waste Toner for GP200 series
The waste toner is collected inside the drum cartridge. It can be emptied by removing the drum cartridge assy and opening the opaque window and emptying into a large bag. The lines on your copies are probably a symptom of the drum being worn out, so replacement is probably a better option. The drum is good for 60,000 copies.
Jul 17, 2008 | Canon IMAGERUNNER 6570 Copier
Waste Toner Full/ Not install still on screen after I emptied and will not print. I emptied container and reinstalled and still same message on screen
Behind the little container for the waste toner there is a sensor that senses whether the toner basket is full or not. If the sensor itself is dirty, it can give a false reading. First try cleaning out the area under the container to see if the switch works. Also make sure the container is clean, because the sensor works by sight, so if it looks full because it's dirty, it will give a false reading. I have heard of people disabling that sensor in various ways, but that can get dangerous to the printer. I can't recall the details on that exact model, but I believe there is a diagnostic of some sort that can test that sensor to make sure it works right to begin with.
Sep 20, 2006 | Samsung CLP-550 Laser Printer
HP LaserJet 4600dn Color Printer Logo
740 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
