Copies are very dark; almost grey.
New toner cartridge was put in, but still dark copies. Can hardly read what is on the copy. This happened once before and cleared itself. Could it need cleaning?
  • Joseph Micallef May 11, 2010
    What is the name and model of your copier?
  • 80 Answers
Is this a color copier? If so are you using the color copier setting? If you are it is coping the color of the paper and it is comming out gray. Not sure but I have had this happen before.
Posted on Jan 18, 2009
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Produces Light Copies
Have you considered changing or checking the toner cartridge?
Does it display a low toner light?
I had a similar problem with a copy machine, where ALL the settings were correct and the toner was light.
The problem was the toner cartridge, the toner was caking because of the temperature. All it took was a good shake at the toner cartridge and it worked.
Also, check to see if the scan bed is messy, a good cleaning the the scanner bed should work as well.
Hope That helps!
Dec 12, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
I have a Xerox XC820. I am getting dark copies with residual images from previous copies. Toner appears to be adhering to the drum cartridge. Do I need a new drum cartridge?
I have a Xerox xc820. The drum kit needed to be replaced, which I did as well as put in a new toner cartridge. The pages are now coming out very dark. Prior to putting in the new drum kit and new toner cartridge, the machine ran fine. I have tried all I know how to do and to no avail. Have cleaned the "wire", all the parts I can get to and cleaned the plate. Any help would be appreciated.
Apr 21, 2012 | Xerox Office Equipment & Supplies
Its me again,after the user changed a new toner cartridge after few copies there is a dark back ground in copy.before replacing the toner the copy was perfect pls help me in this problem
Hi, After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
We are getting black faxes and dark grey copies
I recommend to clean out an optics. Take apart a cartridge and well blow through, clean the rollers and contacts.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Dell 1600 - Print on copies is very, very light. We have put in a new toner and set the contrast to "Darker", but the copies still are light and hard to read.
You can try a couple of things,
1. Verify that the pull strip was removed from the toner cartridge before it was supposed to be installed.
2. Shake the toner cartridge side to side to loosen the toner inside.
3. Clean the inside of the printer with a can of compressed air.
Good Luck!
Rich Lilja
Apr 15, 2009 | Dell 1600n All-In-One Laser Printer
You need a service engineer to clean and service your copier.
Jan 18, 2009 | Office Equipment & Supplies
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Black Copies
is there toner in the machine ? ( toner spill)
check the manual for the location of the glass, in the maintenance section, if it has toner on it copies will be black or dark, other wise the scaning glass is bad
Dec 31, 2007 | Canon LaserClass 7000 Plain Paper Fax
65 people viewed this question
