Question about Fisher and Paykel GWL11 Top Load Washer
Wash machine not rinsing or spinning
I have a fisher paykel model GWL15 Code is reading pump clogged Have checked all hoses there good This had happened in the past we had a repair man out there was a smaal toy caught in the pump he told me if it happens again it is easy to do He should me. I forgot that's how easy it was. My husband and i are trying but there is something we are not doing wright. regaurding the pump can you please help. If I call a repair man they will have to charge me. That why the repair man should me how to fix the problem please help Thanks!!!!!
  • 27 Answers
Remove the panel at the back and find the pump...it will be the unit that sits below a thick pipe which is attached to the drum. On the other side of the pump there is a smaller pipe attached (the drain hose) which leads to the outside. Remove the hoses (normally they only have clips) and remove the pump completely. Once removed, it is easy to remove any blockages from the pump. Some models have a "filter"....look on the side and back of the washer for a round plug about the size of a peanut butter jar...if there is one, open it and remove objects from inside.... Good luck! Oshie
Posted on Jun 26, 2007
SOURCE:
Water spills out when in final spin cycle and when machine is done spinning some water is at the bottom of the tub.what could it be?
check hoses and hose clumps under machine near the pump and where the drain connects to machine good luck
Aug 08, 2011 | Fisher Paykel EcoSmart GWL15
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
I have a fisher paykel ecosmart wash cycle but when
Tip the Washer and check the hoses.... my husband just found 2 pennies stuck in one of the hoses in my F&P GWL15
Sep 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel gw509 not draining, pump is clear
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Mar 04, 2009 | Fisher Paykel EcoSmart GWL15
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Press "end of cycle" for 5 seconds or more to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
JUST BOUGHT THIS UNIT and it will not wash
Nov 13, 2007 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GWL11 Top Load Washer Logo
176 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
